C clips for hood struts
Old Aug 25, 2005 | 02:34 PM
Kandied91z's Avatar
anyone know where you can get these? they usually come with the strut, i lost the clips for one side removing them the other night and need to find something to keep the strut on.
Old Aug 25, 2005 | 03:12 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Junkyard would be the best bet. Maybe an auto parts store. If nothing else, buy new struts
Old Aug 25, 2005 | 06:37 PM
KEVIN G.'s Avatar
Car: 1984 TRANS AM AERO (PAINT SO DEEP
Engine: 305 CARBED
Transmission: 700 R-4/Vette Servo mod
New, they are reeediculously over priced...
We've lost them before when dis-assembling a car...They fly accross the shop... GM wants like 30 bucks a piece for them.
Someone MAY be making them aftermarket. If so I haven't found them.
Edit: I've always been told those are JESUS clips... You work with them and you're always yelling JESUS!!!!!!!!!!!!!@#$$$!!***$%#
Old Aug 25, 2005 | 08:50 PM
Kandied91z's Avatar
lol.. yeah i figured that might be a problem thanks for the insight.
Old Aug 25, 2005 | 08:56 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Someone might have an old set around somewhere.
Old Aug 25, 2005 | 09:46 PM
Camaroz29's Avatar
I got some struts at autozone for 10 or so each. They came with different clips at the bottom then the ones that were on my old ones. I ripped them off with pliers (the only way I could figure out) and stuck with the C clips. Now I lost the pass side C clip and the hood is a little off on that side because I bought another new strut and use the clip it came with. I would also love to find a C clip.
Old Aug 26, 2005 | 01:00 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
Kandied i may have an extra set i'll take a pic tomorrow to make sure they are the same ones you need.
Old Aug 26, 2005 | 01:42 AM
CrazyHawaiian's Avatar
Car: too many ...
You need one or two? I got a bunch of extra ones, one of those parts I snake off parts cars before they get hauled off to be crushed. You pay shipping and they're yours.
Old Aug 26, 2005 | 04:39 AM
irocbirdbuilder's Avatar
Car: 91 Camaro RS
Engine: TBI
I got a bunch of em too, hit me up if you need some, i dont use struts anymore so i have no need for em.....Of course that is a toss in the pocket junk yard item
Old Aug 26, 2005 | 09:37 AM
Camaroz29's Avatar
Just to be sure, the C clip is the one for the bottom part of the srut that slides right on, correct?
Old Aug 26, 2005 | 01:07 PM
Kandied91z's Avatar
i'm not sure exactly what they are called but yes that would be it. i also need the one that slips over the top which is a slightly different shape. i'm out of work early today so i'm going to check and see if i can't find them, i'll let you guys know. thank you!
Old Aug 26, 2005 | 09:18 PM
Camaroz29's Avatar
I need 1 C clip. Bet it'll fit in a letter envelope. Kandied, your old mini starter is still running strong.
Old Aug 27, 2005 | 11:28 AM
Kandied91z's Avatar
that's good.
Old Aug 29, 2005 | 01:44 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
if not the factory hood clips.... you can get a E ring from the hardware store that will do the trick.
.10 cent or so.
good luck.
Old Aug 29, 2005 | 02:00 PM
Kandied91z's Avatar
don't know why i never thought about that, thank you.. sometimes it's the easiest answer that is overlooked.
Old Aug 29, 2005 | 02:25 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
as picky as i am, id get 4.
gotta make them match.
hahahahahah!
Old Jan 2, 2020 | 01:30 PM
z28cop's Avatar
Car: 1985 IROC-Z
Engine: L69
Axle/Gears: 373 Limited Slip
Re: C clips for hood struts
Reviving old thread...Anyone have 2 of these I can purchase?
Old Jan 2, 2020 | 02:20 PM
Drew's Avatar
I don't... I'm assuming you want the real deal style clip they used from the factory and not the modern 'captive' clips? The old school clips went out in the late 90's. I never throw anything away and barely have enough to do one car. Wish I could find an aftermarket source, the OE clips are a lot easier to deal with and don't chew up the peg on the car.
GM # 14036396 Pic for reference.
Old Jan 2, 2020 | 02:44 PM
z28cop's Avatar
Car: 1985 IROC-Z
Engine: L69
Yes I agree! That is what I am looking for. It was my first job ever at GM Norwood to put the right strut on. I took grease from that job that I used on them. I then installed the clips, and seeing how I had unlimited stock.... I would have assumed some would have made it home with me in my pants pockets, but can’t find any in all the nuts, bolts and clips I have in my little box of Norwood treasures lol.
92-Formula
Dec 12, 2015 10:34 PM
Fox118
Sep 12, 2015 09:29 PM
blackandblue02
Sep 10, 2015 08:19 PM
lock1983
Brakes
Sep 9, 2015 09:08 PM
89 formula TPI
Sep 8, 2015 08:00 PM
