bondo won't harden
Old Sep 7, 2005 | 07:35 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
bondo won't harden
So I have this can of short strand fiberglass reinforced filler (actually it is bondo brand...), that's in my garage. About 1 year old. I mixed some up last night to slop on my car, anyway, it's hard to knead the tube of *cream* hardener, since there's air in the tube, it just feels full... anyway, out of the tube of hardener came this watery red liquid... I'm guessing it wasn't mixed/kneaded enough...
I guessed at how much to mix in with the filler, and I suppose I didn't use enough, as tonight (24hrs later), it's still soft, and gooey.
What should I do? Try to remove it all, or can I try to use a heat lamp or something to force cure it...? more time? I'd prefer not to have to remove this incredibly gooey mess...
Old Sep 7, 2005 | 07:57 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
The hardening agent shouldn't be watery, its a paste. Remove what you put on, then get some new stuff.
Old Sep 7, 2005 | 09:53 PM
Sonix's Avatar
Car: 1982 Trans-Am
yea I know, last year when I first cracked into the can it was fine.. I guess the hardener just settled in the tube.... I scrubbed the junk off (boy what a hassle!), and retried it... I kneaded the crap outta that tube, sure enough it was a paste, again....
point of advice, knead that tube good!
we'll see if this sets up ok now...
Old Sep 8, 2005 | 12:04 AM
plathegame's Avatar
Car: 1986 trans am ws6, 66 grandprix
Engine: 88 iroc 5.0 tpi
Transmission: 700 r4 built by rocky pirrone
Axle/Gears: 327
i would take it off and start over because if it doesnt cure right it will crack like hell esp when it gets cold out
Bubbajones_ya
Oct 25, 2015 08:01 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
Luigytico09
Oct 1, 2015 08:46 AM
the_hamturdler
Sep 30, 2015 12:50 PM
