Underneath bumper
Old Sep 8, 2005 | 01:07 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Underneath bumper
Can someone post some pics of the area underneath the car .. leading from the front of the bumper.. all the way to the airdam
I'm missing most of those parts... and not sure what they are supposed to look like .... I got some plastic and fiberglass here but once again.. not sure how the actual layout is supposed to be
The shroud .. radiator there... is hanging loose/may have something missing too
Old Sep 11, 2005 | 07:18 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
hmmmm
Guess not
Looks like I'm SOT until I can get a Camaro service manual
Old Sep 11, 2005 | 07:48 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
this has some of the pieces. 1) Cover 2) Cover support 3) Bracket Center
4) Bracket Side Right 5) Insert Plate 6) Mount panel
7) Impact bar 8) Absorber 9) Stud plate
10) Shim 11) Valance panel 12) Valance
13) Side brace Right 14) Air deflector
Old Sep 11, 2005 | 07:52 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
hmmmm
Without ever seeing what it's supposed to look underneath an actual Camaro .. hard to tell ... but ... it almost looks like I may be missing no.12 .. the valance .. hmmm
Old Sep 11, 2005 | 07:59 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
pic
Here's a few pics I took
https://www.thirdgen.org/techbb2/sho...hreadid=317325
Old Sep 11, 2005 | 08:11 PM
bru333's Avatar
Car: 1987 Camaro SC
Obviously my '87 is going to look different than your '91, I also don't have an air dam, but...
Old Sep 12, 2005 | 01:00 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Ooops
Uhmmmm looks like I'm missing "a few parts" hmmm
What confuses me a little bit is this ... I tried finding the lower valance on Ebay... it lists as 85-90 ... but nothing for 91-92
Old Sep 12, 2005 | 01:02 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
hmmm
I wonder if what I'm missing ... was included in the front lower bumper cover
Old Sep 12, 2005 | 01:18 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
AHA !!
Found part of what I'm missing
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7998171444
I'm missing the airscoop dealy ... and also what I think are bumper support bars ... plastic bars whatever one may want to call them .. that connect the bumper's lower edge to the body ... kinda like plastic stiffeners
Looks like I may have some manufacturing to do
Old Sep 13, 2005 | 11:53 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Well ... now I know
Drove on base today .. saw some Camaro's ... looked underneath them.. of course not all of them had everything in place .. but anyway.. one had.. so.. this is what I'm missing:
1) Air scoop .. leading from front of bumper cover up to the radiator ... not talking about the airdam here
2) Support brackets/supporting plastic edge .. on the very inside edge of the bottom of the bumper cover
3) Left side .. corner ... flat piece right infront of the wheel .. kinda closing in the open area between bumper cover and wheel
4) Same as no.3 but on the right side
Question is ... where do I get these parts ? Can't find them on E-bay, YearOne .. nothing ...
Junkyard is an option .. but Camaro's in the junkyards usually have beat up front bumper covers anyway
Making the parts myself ... well .. last option ... since I have to reinforce the thin plastic sheet I got ... all parts I'm missing are made out of the same thick black ABS plastic as the airdam
Old Sep 14, 2005 | 02:10 AM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
Ok.. well one of them i can tell you you may not find at all.. at least not seperate and that is the bottom part of the front cover those bars that connect it to the body. mine are actually part of the cover... The rest you should be able to find in a local salvage yard as long as it did not take a front hit.
Old Sep 14, 2005 | 12:57 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Yup
Yup kinda figured that one .. regarding the support parts ... actually I think even the air scoop comes with the bumper cover ?
Old Sep 14, 2005 | 04:14 PM
nope. but the bars to.. the rest are other parts... like i said. you can go to the local salvage and if you find a thirdgen camao you should be able to get your parts without much trouble if ou find one that was not smashed in the front end.
Old Sep 14, 2005 | 06:08 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
hmmmm
And those parts did exist on all year models ?
The one I saw which had all parts .. was same year as mine
Old Sep 15, 2005 | 10:48 AM
bru333's Avatar
Car: 1987 Camaro SC
Do you need these?
http://cgi.ebay.com/ebaymotors/82-92...temZ4555368621
Old Sep 16, 2005 | 05:39 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
lol
damn... that's it lol
thanks
Reid Fleming
Oct 10, 2015 09:56 PM
91 SrS
Oct 7, 2015 04:32 PM
