t top weatherstripping part number
Car: 88 iroc
Engine: 355 tpi
Transmission: 700
Does anyone have the part numbers for GM t top weather stripping. I believe the right side is 10198208. I need the left side and also if anyone can confirm the numbers. I have tried the dealerships and have been given different numbers 3 times. I will be getting them from GMpartsdirect and need the right numbers before I order. thanks
Car: 85 Trans Am
Engine: 305 Carb
This is the best pn to use:
10164133
This is a complete kit and includes all the seals needed for the t-tops. Both the left and right seals for the body, and the seals that go on the tops outer edges. I just got mine about a month ago but not installed yet as the car is in paint.
You can get the seals individually also, but I do not have the pn's for those. A search on these boards should turn them up for you.
10164133
Car: 88 iroc
Engine: 355 tpi
Transmission: 700
Well after more calls and more searches I think the other part number is 10198209. Can anyone that has bought the kit confirm this. I can't afford to buy the whole kit and I really need new seals because mine were completly pulled off to get the car repainted. Are the new design body seals compatible with the old design t top seals.
Car: 88 iroc
Engine: 355 tpi
Transmission: 700
Car: 88 iroc
Engine: 355 tpi
Transmission: 700
1992 Trans Am
May 10, 2023 07:19 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
TA8487
Aug 16, 2015 12:21 PM
