Will these wheels fit?
Old Sep 21, 2005 | 10:18 PM
astoria18's Avatar
Car: 1985 Trans Am
Engine: LB9
I searched, but I couldn't understand this offset or backspacing stuff for the life of me. Can someone tell me if wheels with these dimensions will fit, and also explain how to understand all of the dimensions so I don't have to keep asking for each set of wheels I find? Thanks!
Wheel Model = ROH ZS
Wheel Diameter = 17"
Wheel Width = 9.5" (rear), 8.5" (front)
Wheel Bolt Pattern = 5 x 114.3mm
Wheel Offset = 20mm (rear), 25mm (front)
Old Sep 21, 2005 | 11:39 PM
Vibrant_Camaro's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
What i did when i bought wheels for my camaro, was found a site with a fitment chart and just remembered what would fit. So i hope this helps.
Wheels that will fit your firebird.
Wheel Bolt Pattern- 5x120.7 or 5 on 4.75
Wheel offset- Typically 0 (Low Offset - RWD ( Rear Wheel Drive ) Typically 0 offset)
Lug nut- 12mmX1.5
Old Sep 22, 2005 | 12:13 AM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Here's a diagram from the SLP catalog that might helpout. Just plug-n-play with the numbers.
For references:
The stock 16" x 8" wheels have a zero offset on the front and a positive 16mm offset on the rear.
The Ronal Firehawk wheel, also a 17" x 9.5", has a positive 10mm offset.
And yeah, the 120.65mm or 4 3/4" bolt pattern is correct.
And to help with your conversions, 25.4mm is about 1".
Using that material as guides, you should be able to figure out what you need. Happy calculating.
Old Sep 22, 2005 | 12:19 AM
astoria18's Avatar
Car: 1985 Trans Am
Engine: LB9
Wow, great, thanks guys. That was really helpful.
So, 114.3mm is equivalent to 4.5 inches, so I'd need a 5 x 4.75 to a 5 x 4.5 wheel adapter thats about an inch thick to make it work, correct? Like this: http://www.adaptitusa.com/index.asp?...PROD&ProdID=13
Scamo-2.8
May 20, 2016 07:01 PM
kah992
Aug 19, 2015 02:55 PM
greeny
Wheels and Tires
Aug 12, 2015 03:55 PM
milk
Aug 10, 2015 06:26 PM
