Hood Question
Old Oct 16, 2005 | 12:47 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Hood Question
I just installed a 350 with Performer RPM intake and Edelbrock 1405 carb - hood won't shut on this beast.
Will adding a fiberglass cowl to a stock hood work? I was hoping to just cut a hole in my stock hood, and add a cowl. I don't have cash for a whole new hood, and I don't have a garage, and right now she's TOPLESS!
I thought I read where problems arise with painting - something about the fiberglass and metal expanding and contracting differently, and the paint cracks at the transition.
What to do?
Old Oct 16, 2005 | 01:23 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Hood Question
What to do?
What size air cleaner do you have? The hood should be able to close with that intake. I have a friend with an RPM Air Gap on a 400sbc in a Firebird (which has a lower hoodline than a Camaro) and the stock hood closes just fine.
He uses a 14x3 air cleaner. Its a dropped-base style.
Old Oct 16, 2005 | 03:52 PM
Car: 1992 RS
Engine: Carbed 350
Nope - it won't close. Everyone says it will, but it won't. I tried 3 different "drop-base" cleaners, but it ain't gonna happen. I can look across the top and see that the air horn on the carb stands higher than the cowl lip of the body. When I did the swap, I put in new poly motor mounts - maybe that has something to do with it.
I'd sure be willing to try another air cleaner first (before cutting a hole) - someone shoot me a brand and part number from one they have under their stock hood with same setup that worked for them and I'll try it.
Old Oct 17, 2005 | 01:45 AM
Crayz9000's Avatar
Car: '86 IROC, '87 Volvo 240, '09 Malibu
Engine: LB9 5.0L
If you try to bond a fiberglass cowl to your stock hood, you're going to have problems with it cracking at the joint due to body flex. Either make a metal cowl and braze it on, or get a fiberglass hood.
Frozer!!!
Jan 19, 2024 04:55 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
