Swap in mech cluster&dash in 92 camaro
Old Oct 24, 2005 | 11:22 PM
tommy z-28's Avatar
Car: 1985 z-28
Engine: 350ci
Transmission: 700-r4
Anyone ever switched out a electric speedo cluster and dash for an older mechanical speedo cluster and dash?
I need to know if this is a simple swap? Will the mech cluster plug into the same wiring harness as the elec cluster. I really only need the gas and tach to work cause the speedo is done by the cable.
I am trying to simplify my th350 swap cause alot of my wires have been cut relating to the VSS. And I also like the 145 iroc clusters better than my 92 rs cluster.
Old Oct 25, 2005 | 03:28 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
It would likely end up being easier to swap an entire 82-90 dash and cluster with wiring into the car. The earlier cluster doesn't bolt-in; the wiring plugs need to be changed to fit, and repinned as well.
Old Oct 26, 2005 | 11:51 PM
tommy z-28's Avatar
Car: 1985 z-28
Engine: 350ci
If I swap just the face of the dash (the plastic part that goes under the dashpad and houses the vents and guages), the gauges, and maybe cut the wiring and remove like 10" of wire behind both connectors: could I just connect the wires to the ones Id need out of the 92 connector wiring like backlighting, gas, volts, tach....thats it i think? Gonna have autometer oil press and coolant temp.
Anyone done this before, Id like to hear before I go and buy all the crap to try this.
Old Oct 27, 2005 | 01:31 AM
kboehringer's Avatar
Car: 1982 - Z28
Engine: 350 / CCC Q-Jet
Transmission: THM-700R4
Axle/Gears: 10 Bolt - 3.73
NOT EXACTLY......
EDIT: Did some checking and found my suggestion was not appropriate for a '92 as the dash is too different.
Kurt
Old Oct 27, 2005 | 11:12 PM
tommy z-28's Avatar
Car: 1985 z-28
Engine: 350ci
Kboehringer:
Its cool, I didnt even get to read it before you edited.
Anyone else out there done this???
Old Oct 27, 2005 | 11:43 PM
Car: 1982 - Z28
tommy z-28,
I have pulled the entire dash and it's harness out of my son's '82 and it's not that big of a deal. Could be done in a day....EASY.
Kurt
Old Oct 28, 2005 | 02:38 AM
CrazyHawaiian's Avatar
Car: too many ...
They are not directly swapable. I've seen this problem solved in two ways. #1 making a custom plate with cutouts for Autometer guages and mount everything in the custom plate in place of the stock cluster. #2 get the conversion thing for cable speedo to VSS output and retain the stock style cluster.
Old Oct 28, 2005 | 05:01 PM
tommy z-28's Avatar
Car: 1985 z-28
Engine: 350ci
What makes them not directly swapable if I cut the connectors off and reattach to the correct wires from the mech cluster connectors??
Is the physical dash front not going to fit the same or something.
I can get a dash front and mech gauge dirt cheap pretty much every yard has them hear. I dont have the wiring for the vss or even have a vss for that matter to put in a tranny.
Old Oct 28, 2005 | 06:29 PM
Car: 1982 - Z28
TommyZ-28,
Maybe you can swap the ENTIRE dash assembly from an earlier Camaro? I think cutting the connectors off and reattaching them is going to take tons more time to accomplish than just replacing the entire dash & harness. I am certain CrazyHawaiian is correct that the actual instruments will not fit. However, I [B]THINK[B] the entire dash should work with minimal modification (if any).
Kurt
Old Aug 5, 2010 | 07:46 AM
nolmtD2's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Re: Swap in mech cluster&dash in 92 camaro
can this swap be done without changeing the dash by useing the Dakota Digital dash for 82-89 camaros?
Jorlain
Aug 24, 2022 05:11 PM
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Feb 4, 2016 07:10 AM
reiderz iroc
Aug 13, 2015 04:57 PM
Vintageracer
Aug 11, 2015 08:13 PM
