Gauge question
Old Oct 31, 2005 | 08:55 AM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
Gauge question
Ok well all my gauges in my 1990 Camaro work except for the tach. Instead of the needle sitting to the left like when the car is turned off, it is stuck all the way to the right like a buried speedometer and it does not move whether the car is on or off. Is there anything I should look for that could maybe fix this problem? I just wanna maybe fix my factory tach before I go on down the road later and get an aftermarket one. Thanks guys.
Old Oct 31, 2005 | 03:26 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
You could have it rebuilt or source a wrecking yard replacement cluster if you want to keep it stock. The last time I priced a speedo / tach cluster rebuild it was about $200+-. If that's an option for you, do a web search to locate one of shops that specialize in that.
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
