T-top seals
Old Nov 5, 2005 | 05:02 AM
mdelbene's Avatar
Car: 1983 Trans Am
Engine: 305 "H"
Transmission: Automatic
T-top seals
Good morning all,
My son and I just purchased a '83 Trans Am. The seals where the T-tops
meet the side windows are shot. They look to be made up of two pieces -
one appears to be made of foam rubber and the other from black rubber.
What I need to know is if this is correct and also where I can find
replacements.
Finally, is there a trick to removing the latch handle. I tried loosening the screw but it doesn't come out.
Thanks for the help.
Old Nov 5, 2005 | 06:09 AM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
Transmission: gto t56 (mn12)
Im a little confused about the foam part on the t-tops. There should only be a rubber sealing strip and a plastic water run off piece.
You cant buy these seals separate as far as I know. Look to pay a couple hundred dollars for a new set. They have cheesy aftermarket ones and genuine gm replacements. Check with Classic Industries camaro/firebird or with Year One camaro/firebird.
The handle is rusted onto the shaft. Take the screw all the way out and pry that handle off. Or try using a slide hammer with some kinda claw to grap the handle. Hope this helps!
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
