door conversion
Old Nov 6, 2005 | 11:26 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
door conversion
Is it possible to take a door with roll up windows, and swap in the internals from a power window unit?
Old Nov 7, 2005 | 11:06 AM
Toehead's Avatar
anybody know?
Old Nov 7, 2005 | 11:43 AM
Siveck's Avatar
Car: 1992 Camaro RS
Yes, it is possible. I've done this on a few different makes of cars. You'll need to drill out the rivets that hold the regulator to the door. Swap in the power unit and the wiring and switches and you are good to go. You can do the same with the power locks. And power mirrors if you really want. Just be careful if you find yourself separting a power window motor from the regulator. If you find motor/regulator assemblies, then you won't need to bother, but if you do separate the motor from the regulator for any reason, be very careful because it will remove body parts such as fingers and arms if you fail to properly secure the arm assembly.
Old Nov 7, 2005 | 06:16 PM
NEEDforSPEED's Avatar
mmmm oh yes 11 hours wasted of my life for one door
Jerzyperson
Carburetors
Nov 13, 2015 01:07 AM
KNIGHTE
Southern California Area
Oct 22, 2015 09:11 PM
LittleFranks
Oct 7, 2015 11:26 PM
m00n420
Sep 11, 2015 02:39 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
