87 firebird conversion
Old Sep 17, 2015 | 06:01 PM
Jerzyperson's Avatar
Car: 2006 chrysler 300c srt8, 87 firebir
Engine: 5.0/305
I'm looking to change carbs on my 87 firebird 305. And I've heard that converting from the ecu controlled qjet to a no ecu carb is bad on the car. And i know you can do carb to tbi conversion which doesn't use the stock ecu. So my question is how do I swap out carbs for a little more without messing anything up? Can I just unhook and remove the ecu and wiring without doing any damage. Or is there another way around it? And doing so will it clean up all the hideous vaccuum lines covering the engine?
Old Sep 17, 2015 | 06:30 PM
Night rider327's Avatar
Car: 1988 Camaro
Re: 87 firebird conversion
The non ecu carb swap will not hurt anything. You just need to do it right.
You must replace the carb of course but also the distributor. You have to use the older style non ecu controlled HEI large cap distributor.
If your car is an auto transmission you will need a torque converter lockup switch kit as well
Old Sep 17, 2015 | 06:32 PM
Engine: 5.0/305
It's the 5 speed. So that's all I'd need to do is carb and distributor? What do you mean older style? Like gen 2? Or can I find it by looking up large cap HEI distributor?
Old Sep 17, 2015 | 10:04 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Older style HEI as in not computer controlled, but with vacuum and mechanical advance. You can use an old factory unit, or buy a new one.
If you have a factory intake manifold, the square-bore type carbs like Holley or Edelbrock won't bolt to it without an adapter, or replace the intake with an aftermarket type that will take a square-bore carb.
If you put a non-computer q-jet on it, it will bolt to a factory intake manifold.
Since you have a T5, a Holley-type double pumper carb would be better than a q-jet or Edelbrock or vacuum secondary carb.
Old Sep 17, 2015 | 10:07 PM
Engine: 5.0/305
That was the plan. Holley 650 carb. With edlebrock dual plane performer intake and just a mild cam. Maybe do heads down the road.
Old Nov 7, 2015 | 08:19 PM
a62belair's Avatar
Car: 88 Firebird, 87 Formula
Engine: 2.8, 5.0
Transmission: both 700R4
Axle/Gears: 3.42,3.45
When you swap the distributor, use the factory power and tach plugs, and you are good. You won't need the third plug.
Old Nov 13, 2015 | 01:07 AM
five7kid's Avatar
'87 had the small-cap, divorced coil distributor. It doesn't connect like the large cap, coil-in-cap HEI.
But it isn't hard to adapt the '87 power wire and tach signal to the older style large cap HEI.
PATRIOTIC1911
Northern Great Plains and Rocky Mountain
Oct 7, 2022 10:38 PM
1Aauto
Sponsored Vendors
Nov 23, 2015 02:17 PM
bryanwood74
Sep 24, 2015 09:50 PM
J.C. Denton
Aug 31, 2015 03:11 AM
lt1z350
Aug 28, 2015 05:57 AM
