center console light
Car: 89 camaro RS
Transmission: stock
I want to change my center console light. The on for p r n d d 2 1
right now it is stock yelowish orange but i want it to be blue. Could someone give me a link on how to do this. And yes i searched but didn't find anything.
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
On some of the birds they used these little rubbery covers that fit over the bulbs. The ones I've seen were orange tho. I call them bulb condoms, might be blue ones available.
Car: '86 IROC, '87 Volvo 240, '09 Malibu
Engine: LB9 5.0L
Just unscrew the 4 Torx screws holding the shift plate on (I believe they're at the wide front end and at the back, don't do the ones in the middle since they're dummies) and lift the plate up. You don't have to lift it all the way.
Toward the rear of the plate, reach under and there's a wire leading to the back of the shift indicator. Twist and remove the bulb holder, and then you can get at the bulb.
(this was all from memory, so if I forgot anything let me know)
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
