Functional SS hood?
Old Nov 11, 2005 | 04:30 PM
evoluzione1's Avatar
Car: 88IROC vert and a 83 w/evo body
Engine: 400 and 350
Transmission: T56 and 700R4
Axle/Gears: 323 and 373
Functional SS hood?
Do they make a functional ss hood? not the double hump hood. or can it be made using the ram air air filter system?
Old Nov 11, 2005 | 08:24 PM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
Thats a good question. And one I've wanted to answer by making mine functional.
To make it functional, you have to cut out the fiberglass in the hole for better airflow - done
Then you have to custom make an airbox - never tried it
Then you have to put in airfilters and some way to keep water out - the hardest part.
With my TPI 350, you could take off the air snorkle and look through the hood at the throttle body. So its not impossible. But it would take a good deal of fabrication and thought.
The real question is, has anyone completed it already, and would they be willing to show pics and give measurments.
I havnt put my hood back on yet, but I do think my LS1 will also sit far enough back that I can fab a box....can't wait to see
Old Nov 12, 2005 | 12:15 PM
IROCNParts's Avatar
Car: 1988 IROC-Z Convertible
Engine: 408 Stroker Turbo, TPIS Mini Ram
Transmission: Magnum t-56
Axle/Gears: Ford 9" 3.55
I think with an LS1 u might be able to use the stock SS air intake as it sits upside down with some modification.. well thats my plan at least.
Old Dec 1, 2005 | 11:42 AM
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
Transmission: T-56, Viper output shaft
Axle/Gears: Strage 12-bolt 3.73:1
I would like to do this as well! I am switching to an SS hood and I would like to make it functional, however, I have a miniram setup so I hope that too will give me enough room to mount the air box.
Old Dec 1, 2005 | 03:57 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
If you have a carb or TBI setup then you could cut a hole in the bottom of the hood and maybe fit a Ram Air intake from a 70's F-Body under there.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
mr z28
Exterior Parts for Sale
Dec 14, 2015 05:14 PM
IROCTheHouse
Oct 26, 2015 02:35 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
