Trunk lock problem
Old Nov 15, 2005 | 07:02 PM
Steved1257's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.08
Trunk lock problem
hey, the other day i went to open my trunk and my key slipped in but i wasnt able to move it at all.I sprayed some lubricrant in the key hole but its still not able to move, i was wondering if anyone has ever had this problem or knows how to fix it. thanks
Old Nov 15, 2005 | 07:08 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Mine does that sometimes too. I just move it around a little bit until I find the right spot.
Old Nov 15, 2005 | 07:13 PM
Steved1257's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.08
ill have to try that tomarrow thanks a lot
Old Nov 15, 2005 | 09:34 PM
subliminal's Avatar
Youll probably need to replace the lock
Old Nov 15, 2005 | 11:34 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Sounds like your lock is worn out. Did you lube it twice a year like you are supposed to?
Old Nov 16, 2005 | 12:56 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
It sounds like your key is worn. I had the same problem. A local locksmith was able to make me a new key by examining the worn key and making an educated guess as to the original pattern of ridges and valleys. Of course you can also have a new one made from the dealer if you have the key code. Your easiest solution is to replace the lock and key. You can get a complete set of new door locks, trunk lock and storage compartment locks or just the trunk lock from Classic Industries.
Lon
Old Nov 16, 2005 | 07:22 AM
subliminal's Avatar
If the lock is shot u dont need to buy a whole new set of keys, You can take the new lock down to a locksmith and they can rekey it to the key u have. no need to replace all of them.
BRoss99
Aug 10, 2025 05:08 PM
colton_carlson
Mar 8, 2019 12:21 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
CORV3TT3
Aug 23, 2015 11:26 AM
mx127
Aug 10, 2015 08:13 AM
