Help, ? about center t-top bar
Old Nov 19, 2005 | 12:52 PM
wills83z28cfi's Avatar
Car: 07 Silverado
Engine: 5.3L V8, flexfuel E85
Transmission: 4spd. Auto
Axle/Gears: 3.73 locking diff.
I have a few questions for you guys about the center t-top bar that mounts to the body. My local chevy dealer told me there are 2 different bars for our cars. One is for 82-85, and the other is for 86-92. My buddy has a 89 camaro and by looking at his I can't see any difference, and we also tried my t-tops on his car and they worked just fine. So, does anyone really know what, if any difference there is? Has anyone done what I am trying to do by putting on the later model bar or vice versa? Oh I should mention the whole reason I am asking is because GM has discontinued the 82-85 bar, but still has the later model one. Any info will help, thanks guys.
William
Old Nov 19, 2005 | 06:49 PM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
I can't anwer your question, but I bought a used later model center molding for my 87 from them. It was a very usable piece with minimal rust.
I had it sandblasted, then I used a gel type aircraft paint stripper to get the glue from the old weatherstrip off the metal. Worked great.
These guys have used pieces for your year in stock for $65.
EDIT: http://www.fbodymotorsports.com/inc/sdetail/13782
Old Nov 20, 2005 | 02:25 PM
Car: 07 Silverado
Thanks for the info and help. I finally got someone from my local dealer to do some research for me and he found out it's only a cosmetic difference between the 2 bars, and either one will mount and work with any 82-92. So I bought a new one from them.
Old Nov 23, 2005 | 01:33 PM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Do you have that bar part number?
Jari
Old Nov 24, 2005 | 02:38 PM
Car: 07 Silverado
Don't have the part # yet, when I pick the part up I will post it for you, give me a day or so.
Old Nov 24, 2005 | 02:59 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
The reason there were two different T-bar styles was because the 1982-early 85 T-Top hatches have plastic trim around the outer edge so they're a little thicker. The trim was ommited starting in late-85.
I've tried both style T-Tops on early and later cars and didn't notice any fit problems. The rubber weatherstripping seems to be thick enough to keep the hatches tight.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
dimented24x7
Sep 17, 2015 06:58 AM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
