Lost cause? (doors)
Old Nov 20, 2005 | 03:42 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Lost cause? (doors)
I just bought mint rust free doors. I put them on, got the doors to align properly, then set about adjusting the windows. I just got the windo perfect when I notice that the number one rivet holding the motor on (the one furthest up ) had cracked the metal around it when I was adjusting it. I have nev er adjusted the window before, and I didnt read the artcile beforehand (want aware of it ) but I just read it and I think I was doing everything right. The insied panel of the door, where the motor is rivetted, also seems to flex inward excessively when the window reaches the top. What would cause this? Is this door a lost cause, or can I fix the damage? Please advise
-Brendan
Old Nov 20, 2005 | 06:51 PM
camaro430sut's Avatar
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
most thirdgen doors that ive seen have had this crack. it just seems like a weak area under alot of stress from the motor. ive never heard of anyone having a problem with the crack being there as long as it isnt huge.
matt
Old Nov 20, 2005 | 06:57 PM
Toehead's Avatar
I think I am going to weld the cracks, smooth, weld a washer over them, then weld in some thick bar stock to keep the area from flexing again. Think that would work?
edit... If i don't do something about it, it will get huge. there is no reason the area should flex like that either, with proper reinforcement. I just verified with my other door that the flexing isnt anything out of the ordinary.... however, metal fatigue is cumulative, and i want to stop this before it becomes a problem. I'll probably do the same for the other door i'm installing too
Old Nov 21, 2005 | 12:51 PM
Toehead's Avatar
Old Nov 22, 2005 | 11:09 AM
Toehead's Avatar
Maybe I should rephrase that.... has anybody else reinforced that section? Is it a good idea? Or, should I just repair the damage and call it good?
Old Jul 3, 2006 | 02:29 PM
Scottlb9's Avatar
Car: 1991 Formula
Engine: 5.0 TPI
I just picked my car up from having this done only a few minutes ago!
The cracks were welded and smoothed and a plate was welded on top of that and re-rivited.
So my answer is "It cant hurt to fix and reinforce it".
Old Jul 3, 2006 | 02:49 PM
TKO500's Avatar
Car: 91 B4C, 17 C7 GS, 16 Denali DMax
Engine: LS3, LS3, LML
Axle/Gears: 3.23, 3.42, 3.23
I just did this exact same thing to my door 2 weeks ago. On my door the stress of the rivet actually blew a hole right through the sheetmetal in the door.
I definately recommend doing the same thing as Scottlb9 did. You wont have to worry about it happening again!
Veaceonee
Sep 29, 2016 08:15 PM
LC2 TECH
Interior Parts Wanted
Jan 27, 2016 08:38 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Buggy Disaster
Sep 17, 2015 05:12 PM
IROCZDAVE (88-L98)
Sep 17, 2015 07:43 AM
