Another "What's This?" Question!
Old Nov 20, 2005 | 09:40 PM
JMJ2003's Avatar
Car: A beater.
Engine: Not enough HP.
Transmission: Automatic... I can't drive a stick!
Can someone tell me what this is and how to get it out???? Thanks...!!!
Old Nov 20, 2005 | 09:49 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
you can get a chiltons or haynes manual to remove this. it is held on by only a few screws. I beleive it is a filter for the air into the cabin of the car. check out this for more info.
http://www.iroc-zpostforum.com/Tech/TechFREndBody.htm
scroll down about half way to see the mystery peice.
Old Nov 20, 2005 | 09:53 PM
jandl22's Avatar
Car: 82 White Stock Camaro
Engine: 2.5 151 TBI
Transmission: 4 Speed Manual
Re: Another "What's This?" Question!
Bro, please look at it and just remove it. It is as easy as 123?
Old Nov 20, 2005 | 09:54 PM
JMJ2003's Avatar
Car: A beater.
I'm a giiiiirl....!
Old Nov 20, 2005 | 09:56 PM
jandl22's Avatar
Engine: 2.5 151 TBI
Sorry,
I meant Bra!
Old Nov 20, 2005 | 09:58 PM
JMJ2003's Avatar
Car: A beater.
No biggy... I can't figure out how it's held down though... One of my friend's told me it just pop's off... but it ain't poppin'!
As for Haynes, I looked... Can't find anything in there... Maybe I'll go read the book again...
Old Nov 20, 2005 | 10:00 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
the other post has where the location of the bolts are. then when you get them out you can just pop it off.
Old Nov 20, 2005 | 10:03 PM
jandl22's Avatar
Engine: 2.5 151 TBI
Hi again,
Just look at it close up, if there are any type of fasteners holding it down then use the properl tool to remove it. I have removed a few of these in my days but I can't recall what tool it takes at this moment. If you ever need help hun please PM me.
Lawrence
Old Nov 20, 2005 | 10:32 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
see the little tab that extends towards the driver's side? That is held in by one of those little one way break-when-when-you-pull plastic fasteners
Old Nov 21, 2005 | 08:50 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
I'm a giiiiirl....!
I think it's the playboy bunny icon and the fact that this site is about 99.99999999999999999999% male that is mixing people up. I just figured this out in another post where you had to state your gender.
I will have to agree that it is a break when you pull plastic peice. If you need to remove it, you will need to find a good one (used) or purchase a new one to replace it.
Old Nov 21, 2005 | 08:58 AM
JMJ2003's Avatar
Car: A beater.
Sadly enough, I have never had any trouble before with identifying my gender!
LoL!
<3
Old Nov 21, 2005 | 09:29 AM
Nikole's Avatar
Car: 1992 RS
I would say if you are having a tough time with it, or it breaks upon removal, you should hit up a local salvage yard and either get yourself a replacement piece or practice taking one off there. If you break that one~ just walk away.
~Nikki~
Old Nov 21, 2005 | 10:01 AM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Not that gender really matters, right?
Yeah, that screen is the intake for the cabin air. I found this out when mine got broken, some leaves got in, and then for the next couple of weeks whenever I turned the inside fan on, crushed leaf bits flew through the vents...
Old Nov 21, 2005 | 10:23 AM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Transmission: 700R4 + Shift Kit
Axle/Gears: Auburn Posi; Richmond 3:73 Gears
lololol sorry had to... thats actually funny.. Mine sorta does this in the fall cause the foam insert is pretty much shot so i get pollen in the car when i turn mine on.. but as to the question mine is held by like 6 clips witch are held by screws if i rember right you remove the screws and just remove the screen.
Old Nov 21, 2005 | 10:47 AM
Nikole's Avatar
Car: 1992 RS
yeah i have to agree with this...gender doesnt make much of a difference.
Old Nov 21, 2005 | 11:02 AM
JMJ2003's Avatar
Car: A beater.
Bwahaha...
One of my friend's is ripping his Firebird apart, for what reason I don't know, and he said I could come practice on his car... I'ma go do that... Hopefully I'll get it figured out so I don't gotta go buy new ones...
Thanks for the help guys!
And ya all are right, gender doesn't really matter!
Old Nov 21, 2005 | 04:03 PM
KissThis's Avatar
Car: 1984 Firebird V6
Hey, to fix your Sig.. take out the <'s and replace them with ['s and your Sig will work
Old Nov 22, 2005 | 03:42 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Oh, and to finally get the thing off after you remove the 1 screw holding it on (in the middle), you have to remove the wiper arms... The rest of it just snaps in place.
It's there to keep large debris out of the HVAC system, such as leaves and lumps of snow (but you don't have to worry about snow, do you).
Old Nov 22, 2005 | 08:25 PM
JMJ2003's Avatar
Car: A beater.
Thank ya guys so much for the help... Ya all are amazing!
I finally got it off, just wanted to clean it thoroughly!
<333
Old Nov 22, 2005 | 09:08 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
If anyone's interested, I believe that part is called a cowl screen.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
