Converting Digital Dash to Analog????
Old Nov 26, 2005 | 03:38 PM
GTAPhoenix's Avatar
Is is possible to convert a Trans Am GTA Digital Dash to an Analog "Gauges" Version? IF you can, how complex is it in terms of the wiring if at all? I ask because if I find the "right car" and it has the digital dash, I will surely want to switch it out to analog as I do not care for the digital stuff.
Any helpful information on this would be appreciated!
Old Nov 26, 2005 | 08:26 PM
tagta189's Avatar
The analog stuff is horribly innacurate.I guarantee you the digital stuff,simply because of its design, is far more accurate.The only real variable is the accuracy of the sensors on the engine.With the analog stuff you have needle placemant accuaracy & sweep mechanism errors & all kinds of stuff piling up.Not to mention just really cheap crappy factory gauges.Stick with the digital,they are also worth alot more.
Old Nov 26, 2005 | 10:02 PM
87transkid's Avatar
Car: 88 Formula
Engine: 350 TPI / supercharged
Transmission: 5spd manual / dual friction centerforce clutch 373 rear end
if you dont want those digital gauges i will pay for them. and by the way its not hard converting to analog i did it once allready on my 89 gta and it was a bet i will never forget well enough said. but you can do it
Old Feb 3, 2006 | 10:18 PM
3rdGenBlackBird's Avatar
What's involved and parts do you need?
Scott
Old Feb 13, 2006 | 11:51 AM
87transkid's Avatar
Car: 88 Formula
two wireing diagrams on of a digital gauges and one of analoge and some butt splices and wire then your good to go
Hotrodboba400
Dec 10, 2019 07:07 PM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
Pilotrick50
Sep 2, 2015 12:48 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
