T-top seal window saver......???
Car: 89 IROC-Z / 11 2500 Sierra
Engine: 5.7 & Duramax
Has anyone done a auto window mod to a 3rd gen camaro.....???
Let me explain..... I've seen some high end cars that don't have the window frame like our camaros. When you open the door the window rolls down about 2 inches then when you shut the door it rolls back up. This saves the weather seal on the t-tops and front side..
So I figured a small relay wired with the door light switch....??
-Bill
-Bill
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Won't do much, if anything. Do you really want to know why?
1. You need a switch that knows the second the door handle is triggered.
2. You'll have to wait for the window to roll down since our windows are slow.
3. It still won't do much since that rubber is flexible enough that getting tapped by the window won't damage it more than being exposed to UV rays from the sun every day.
4. It'll be more than just a relay.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
blackandblue02
Sep 10, 2015 08:19 PM
