Questions about headliners and a Part name
Old Dec 20, 2005 | 06:33 PM
TunedPort's Avatar
Alright, my headliner is finally beyond repair...There are glue marks in the cloth and the headliner board is falling apart.
I am going to get a new headliner board and material from yearone. I am getting the 214 dollar job so I dont have to deal with messing up the glueing and creases in the material..
Here are my questions, does it just bolt up there or do I have to buy equipment to hold it up in the car. Also, the plastic piece behind the headliner on the roof is cracked; from the factory, someone tightened the screw too hard. What is the name of this interior panel and where can I get one new. Also does this panel come in the original colors or do I have to paint it?
Thank you for your time,
Tuned Port.
Old Dec 21, 2005 | 06:00 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Check local auto reuphostrey shops. They are a better route to go and may be cheaper and still have a factory look. Had mine done for $140 and can't tell the difference from the original.
Old Dec 21, 2005 | 08:50 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
the headliner is held up by all the plastic panels surrounding it, and i believe 3 or 4 clips in the front, in order to remove them you have to take all the panels off and then slide the headliner towards the pass side of the car
Old Dec 21, 2005 | 08:05 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
actually there are two clips that hold it in the front near the middle and the screws for the visors also support it. In the back, it's held in by the plastic interior piece that you're saying is cracked. best bet is a salvage yard for that piece. A lot of them are cracked though, it's very common for that to happen to them for some reason.
Old Dec 21, 2005 | 09:54 PM
TunedPort's Avatar
No idea on the name of this piece of molding?? yeah the board on my headliner is finished as well.. I am going to get the whole piece finished and preglued from YearOne. I just want to find another one of those panels. I have the custom Flame Red Interior, so finding it at the Junkyard would be a problem.
Old Dec 22, 2005 | 09:26 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
I'm not sure what GM named that interior piece, if there even is a name for it. I just checked a tan and a black piece that I have lying around and both are part # 20235800. And what's custom about a stock interior color
Frozer!!!
Jan 19, 2024 04:55 PM
redmaroz
Aug 16, 2015 11:40 PM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
TheJoeY88
Aug 13, 2015 06:51 PM
1nastygta
Aug 8, 2015 07:38 PM
