Someone hit my rear in parking lot!
Old Dec 29, 2005 | 08:21 AM
fisherpard's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Someone backed into my rear bumper of my 91 Camaro Rally Sport and put a dent in the corner about the size of your fist.
I tried pulling it out with a dent puller but the screw would give loose before popping it back out.
I was wondering if I removed the rear bumper and took a rubber mallet could a knock it back out.
How hard is it to remove the rear bumper? I looked under the bottom and saw a row of about 8 bolts. I could never determine the size of the bolts. After removing the bolts are their any other things you have to do to get it off?
I am not the best mechanic so I need a good detailed description.
Your help would be greatly appreciated,
fisherman
priderock@charter.net
Old Dec 29, 2005 | 08:34 AM
Frank89IROC's Avatar
On the bottom of the bumper, they are just plastic push in connectors, be careful removing them (use small screw driver, to pry & pliers, to pull) because they break easily, but can be purchased in any good auto parts store. The inner spare tire plastic cover & the cover that goes against the rear (inside trunk) will have to be removed to access 3 nuts (10mm, use a deep 1/4" drive socket) at the very inside corner of each side of the rear of the car, the 3 nuts also have to be removed on the driver side corner, you don't have to remove the entire panel to access the nuts, just remove a couple of the plastic screws. Also the 2 screws that hold the rear license plate holder will need to be removed.
Frozer!!!
Jan 19, 2024 04:55 PM
mustangman65_79
Apr 14, 2017 05:37 PM
TheExaminer
Aug 26, 2015 04:59 PM
kyleb24
Aug 15, 2015 08:24 AM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
