removing the rear seat "stud"
Old Jan 7, 2006 | 03:21 PM
jerpoh's Avatar
I'm trying to remove the rea interior plastic panels so i can get to the rear speakers and i got snagged on the rear seat stud. I'm talking about the one metal stud on the passenger side which holds the rear seat up. It looks like it can take a large torx screwdriver right in the middle but i wanted to make sure that it's supposed to come out first. It looks as though i could just slip the plasic panel over it and not even remove the stud but i don't want to have to cut off the little plastic cover on the stud. Any help would be appreciated, THANKS!
Old Jan 7, 2006 | 03:27 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
The tool is a T-50, and attaches to a ratchet. It is also the same bit to remove seatbelts and the rear hatch shocks. Get one and keep it, they come in handy. If I remember I had to take it out to remove the panel.
Old Jan 7, 2006 | 04:11 PM
VERTIGO Z28's Avatar
Car: FBODYS
Engine: ALWAYS 8'S
Transmission: ALWAYS MENTAL
Axle/Gears: RUSTY AND BRAND NEW
T47
Old Jan 7, 2006 | 04:28 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Originally posted by KEVIN L.
T47
I have a T-50 and it works just great, a must have for going to the JY.
Old Jan 7, 2006 | 08:46 PM
MNformula350's Avatar
T47
That's what i use as well
Old Jan 10, 2006 | 02:34 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
T50 will work, T47 is a perfect fit. Also, in regards to the original post, you don't need to remove the plastic to get to your rear speakers. You only have to remove the hook that's held in by a philips head screw. once that's out, the fabric covered speaker cover can be shifted up and pulled off to give you access to your rear speakers.
Old Jan 10, 2006 | 11:25 PM
jerpoh's Avatar
Oh, i guess i forgot to mention i have a standard so it didn't come with rear speakers, so therefore there's no sail panel to just remove. I bought the brackets to mount the 6x9s in the rear wall so i have to take off the entire panel to install the bracket. Now i habe to decide whether i should just drill a bunch of holes in the panel over where the speaker is or try to mount some sail panels where they weren't intended to be. Any advice?
Old Jan 11, 2006 | 02:09 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
having a standard has nothing to do with not having rear speakers..... i believe the only cars that could be gotten with the stereo delete were the 1LE cars.
Old Jan 11, 2006 | 07:28 PM
jerpoh's Avatar
I don't know how to determine what's a 1LE and all those things but here's my car:
1985
2.8Lv6
manual windows and locks
manual radio (when i first got it)
no rear spoiler
and definitely no stock rear speakers
Old Jan 11, 2006 | 10:14 PM
Car: FBODYS
Engine: ALWAYS 8'S
A 1LE is not what you are working with. Your kickin it with a base model camaro. You need to go hunt a set of rear plastics with speaker grills to make it look factory. Should only cost a few bucks at the scrapper. Good luck brother.
Old Jan 11, 2006 | 10:16 PM
Car: FBODYS
Engine: ALWAYS 8'S
Basicly a 1LE is a factory produced race car. I'll leave it at that! Period.
Old Jan 12, 2006 | 07:32 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
can I see a picture of rear panels without provisions for rear speakers? I've never seen that before and didn't know they existed.
Old Jan 12, 2006 | 03:56 PM
jerpoh's Avatar
I'll get some pics up, give me like 2 days. Does anyone have any rear plastics in grey? If not ill keep searching the other posts. Shipping will be a bitch though. Do you think they'd have them at regular junk yards?
Old Jan 13, 2006 | 03:23 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
I've been to several junkyards on a regular basis and seens plenty of f-bodies, but i've never seen the style you're describing. So if you are looking for that type, it'd be hard to come by. If you want ones with the rear speakers in grey, that shouldn't be hard to come by at all. I look forward to seeing the pics
Old Jan 13, 2006 | 10:03 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
Originally posted by 87CIZ
...i believe the only cars that could be gotten with the stereo delete were the 1LE cars.
Nah, the base models (at least the earlier ones) could be purchased that way.
I bought an A/C delete box from an '86 Camaro in the junkyard that had NO options I could see. It had no a/c, rear speakers, rear spoiler or even rear defroster. I almost bought the rear plastics just because I'd never seen any without the speakers in them.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
MORREALE5
Sep 13, 2015 09:16 PM
3rdgenparts
Aug 8, 2015 07:09 PM
z28addict8490
Aug 7, 2015 08:48 PM
