Steering wheel spacer
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
I have an 89 Formula (no airbag)
I like the stock steering wheel, but want to space it 1-1 1/2" closer to me. I did a search and saw where someone said the adapter they'd used on an aftermarket wheel had spaced it closer to them, but this is a case where the wheel is the factory one.
Does anyone know how I might go about this?
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
It's going to be a lot tougher to do that with a factory wheel, especially a formula wheel, because I think the splined section is pretty much permanently attached to the wheel. On the Z28 wheel, you can separate the wheel itself from the shaft, so you could build a spacer. I don't recall whether the standard firebird wheel can come apart like that or not.
While it's probably possible to rig something up for that formula wheel, I think your life would get MUCH easier if you bought an inexpensive Grant wheel and made a spacer for that.
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
yah grant sells spacers for there wheels...id say get an aftermarket wheel and run a spacer on that...even try it w/o the spacer the grant wheel might come in towards you some anyhow.
Engine: L03 305 TBI
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
