1996 trans am dash board
Old Jan 20, 2006 | 05:34 PM
SnkSknrZ28's Avatar
Car: 1988 Camaro IROC-Z
Hey guys, i have a guy selling a 96 ta dash board, im' thinking about doing the swap into my iroc. i looked up the ls1 style dash and they look exactly the same except for the center console. anybody swap this style dash? any pros cons, if its all good im gonna jump on it and buy it
thanks
Mike
Old Jan 20, 2006 | 10:36 PM
Slepewesel's Avatar
Car: 91 Camaro Z28
Engine: 5.0 TPI (LB9)
Transmission: 4L60
Old Jan 21, 2006 | 12:22 AM
SnkSknrZ28's Avatar
hey thanks for your help buddy, anybody else wanna post just to get your post count up?? i no how to use the search and i did, i would not make a post if i couldnt find it in a search first. So with that said...
DURING MY SEARCH i found alot of 99+ dash swaps but no 96-97 swaps. SO AGAIN my question was is a 96-97 lt1 TA dash the same as the 98+ dashes, anybody swap these years? How about the door panels??
I no the center consoles are differnt, it was said in one post that if you are using the console ONLY with your stock 3rd gen dash do not use the lt1 styel because it leaves a gap. i however am swapping the entire dash so do not fall into that catagory.
thanks mike
Old Jan 21, 2006 | 11:03 AM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
if you couldn't find the info, i'll lay out what you need here as best i can. there are differences between the LT1 dash and the LS1 styled dashes. The differences (as i ahve seen then) are in the length of the radio/hvac center section. The length is longer on the LS1 dash than it is on the LT1 styled dashes, because there are differences in the center consoles, and as a result, they don't mesh up quite the same (interchanging center consoles...least that was the result in mine...i had an LS1 console w/ a 96 dash, and there was a 1" gap, so i swapped to a 96 console, and no more gap). Also have the door panels from a 96 in my car, all in all, everything went together well, looks good, and i'm happy w/ it for now, still has some finishing that's needed, but, all in time...Things to also take into consideration are the color differences, 98+ had a ebony/black dash, while the 96 models was a gray unit, or atleast all the 93-96 units i found were gray.
Old Jan 22, 2006 | 05:35 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
97 dash here..
I say go for it.
Jorlain
Aug 24, 2022 05:11 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
The_Phoenix
Feb 4, 2016 07:10 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
