need so help
Old Jan 26, 2006 | 05:30 PM
easternjane2006's Avatar
Car: 83 camaro Z28
Transmission: th350
need so help
i m having troble taking out door panels any help
Old Jan 26, 2006 | 06:19 PM
DJCobol's Avatar
Car: '89 Black IROC 'vert
Transmission: 700-R4
Axle/Gears: 2.73 posi
2 big allen head bolts hold the armrests on the door. Take those out. There should be 3-4 smallish torx screws holding the handle/lock assembly. Take those out too. Use a small flatblade screwdriver to remove the sliding lock indicator from the actual lock rod itself. Take the handle/lock assembly out now. Starting down at the bottom rear corner, gently pry your door panel away from the door. There should be 10-12 plastic push rivets holding the panel to the door all around the sides/bottom. Once all of those have been pulled out, the only thing holding the panel to the door should be the top plastic trim piece. Slide the whole works about an inch or so twoards the back of the car and you should be able to lift it all off the door now.
Go have a beer. You are done.
Old Jan 26, 2006 | 07:57 PM
hmmurdock_00's Avatar
Car: 1985 Trans Am
Engine: 305 5.0 LG4
Transmission: 700-R4 Auto
last i remember the arm rest was held on by 3 large torx head bolts. Also there is a screw behind the door lock button panel, it also is torx, head, it is the one near the mirrior control. But what he described is the whole process to it.
Old Jan 26, 2006 | 08:08 PM
DJCobol's Avatar
Ah, you are right. It is three. 2 in the armrest part and 1 up at the top.
Old Jan 27, 2006 | 12:09 PM
Car: 83 camaro Z28
Transmission: th350
thank you guys very much thats why i love this site
Old Jan 27, 2006 | 12:25 PM
Car: 1985 Trans Am
Engine: 305 5.0 LG4
your welcome.
Old Jan 27, 2006 | 12:28 PM
HisDivineShadow's Avatar
Car: 1991 Trans Am GTA
Engine: 350 TPI (L98)
Transmission: TH-700r4
Related question, how do I remove the door-trim panels? Do they just come off with force or do I need to open the door from the inside?
