Are 3rd gen doors swappable?
Old Jan 26, 2006 | 07:14 PM
TheProfessor's Avatar
I'm trying to replace the passenger side door on my 85 camaro. Ive pulled a door from an 83 camaro and attempted to bolt it on. However, it's not fitting that well . Are all 3rd gen doors the same? Who should I take it to to get the door adjusted?
Old Jan 26, 2006 | 07:19 PM
1992rs/ss's Avatar
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
the doors on every f-body from 1982-1992 are identical. you can put a door from a '83 Firebird on a '91 Z28 for example. unfortunetly the variation of fitment from car to car is quite a lot. take it to a body shop. they will be able to align it correctly. I would also take the time to replace the door hinge pin replacement with the kit from Top-Down Solutions, keep that new door from sagging.
Old Jan 26, 2006 | 08:14 PM
Thanks for the quick reply. I'll have to take it to a body shop and get it straightened out. How much should I expect to pay? I'm attempting to restore my 85, and I've never worked with cars much.
I'm also going to need to rewire the door. Is there a recommended manual / reference for f bodies?
Old Jan 26, 2006 | 09:07 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
There's an article on replacing door hinge bushings/pins in the March '06 issue of "Chevy High Performance" magazine.Nice to see the pictures of it being done.This is something I'll be doing in the very near future(at least the driver's door for now).And I'm going to have to replace my passenger door too because of rust along the door bottom(result of missing window sweeps).
Old Jan 26, 2006 | 11:35 PM
CrazyHawaiian's Avatar
Car: too many ...
Being into drifting I've seen quite a few door swaps, even done one myself. If you crash and the door gets smashed its easier to swap another one on than it is to repair the smashed one. The best way I've found to align the replacement door is to spray a quick shot of paint over the old hinge to leave an outline when its removed. Then when you put the replacement on to line it up you have a template. Not everyone will agree this is the best way since it will leave paint behind but I think it works good. Mainly because I dont really care what it looks like right around the hinge area since its a hidden area. You could only tell if the door was open and someone looked closely.
Old Jan 27, 2006 | 01:04 AM
FMEDIC191's Avatar
Car: 86 Firebird
Engine: V6
Great idea about spraying the hinge. Did it this afternoon worked great
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Warlocksirix
Sep 3, 2015 12:26 PM
neekolzun
Aug 24, 2015 04:59 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
