power window conversion
Old Jan 27, 2006 | 01:04 PM
82 Pace z28's Avatar
Car: 82 Z28 Pace Car Edition restoration
Engine: 5.7l
Transmission: t56
Axle/Gears: 3.23 open drum (not 4 long)
Hi
Can power windows be added to a door that doesn't surrently have pw. Has anyone done it? How bad is it. Do I just need a couple of donor doors? Thanks.
Old Jan 27, 2006 | 05:22 PM
groundrat's Avatar
Car: 91Z28
Transmission: WC T-5
Axle/Gears: 10 Bolt Posi, 3.08
Before everyone jumps in and says search, yes it can be done. Easily depends on your skill. You will need both door motors and regulators out of a donor. Also as much of the stock wiring as possible. You will also need a very large rivet gun and 1/4" peeler rivets (GM dealer). You will have to remove the verticle window support channel. Then you pretty much grind/drill/cut off the old rivets and slide the entire assembly off of the window. Install the power one in reverse order but use the 4 holes that you did not use before. You will see what I mean. Then reinstall the verticled support. And wire it up. I would advise you to replace both motors as now would be the best time BEFORE you install them. Good luck!
Old Jan 28, 2006 | 02:17 PM
Engine: 5.7l
Transmission: t56
Thanks much!!!!!!!!!!!!
Old Feb 1, 2006 | 09:07 PM
sgt0704's Avatar
Car: 91 camaro rs
Engine: 305 tbi
Transmission: 5 spd
Axle/Gears: what ever stock is
i would say, if your car is in the needing of painting soon, just use the donor doors on your car. **** all of the other ****. it's much easier than doing all of the cutting and crap. i replaced the motor and that was a pain in the *** itself.. plus your car may already have the wiring set up for pwr wnds... otherwise, grab all of that from the donor car.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
