Tranny Crossmember
Old Jan 31, 2006 | 12:07 AM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
Tranny Crossmember - Delete
I was pulling my motor and tranny the other awhile back and when I removed the tranny crossmember I managed to break 3 of the four bolts. What should I do? I take it I'll have to drill them out, and then fill the hole with some sort of metal filler and re-tap it? Anyone got any suggestions?
EDIT - DELETE THIS. PROBLEM SOLVED
Old Jan 31, 2006 | 09:14 AM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
Axle/Gears: 9" ford 35 spline axles
use an ez-out. which is basically drilling a hole and putting the ex-out in the hole, then backing the broken bolt out.
Old Jan 31, 2006 | 09:29 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
If you have a dremel, you can try notching the end of the bolt, making it like a flat head screw. Then maybe you can back it out with a large screwdriver. I'd recommend soaking the bolt in penetrating oil first.
Old Jan 31, 2006 | 10:50 AM
Engine: 400
I will probably cut that section of the frame out and fix it up. Problem solved.
-Greg
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
kammi10
Nov 9, 2015 08:28 PM
bjpotter
Oct 4, 2015 07:48 PM
tmork454
Sep 29, 2015 06:33 PM
TOMcat GTA
Sep 15, 2015 09:31 AM
