Fixed Antenna to Factory Power Antenna
Old Feb 1, 2006 | 08:44 PM
alivenkickin29's Avatar
Car: 1989 Trans Am
Transmission: 7004r
Does anyone know if this can be done? My 89 Trans Am has a fixed mast antenna and I want a power antenna -- what will i need to put in a factory GM antenna? Any additional wiring?
Thanks!
Old Feb 1, 2006 | 08:52 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
i'm not sure what you need to convert but i do know you'll need a positive ground and power antenna remote wire. So you'll have to run those for sure. But shouldn't be too awful bad. worst part will be running the power antenna wire.
Old Feb 1, 2006 | 08:56 PM
Car: 1989 Trans Am
Transmission: 7004r
fixed to power antenna Trans AM
Do you know if the good ole GM execs made the wiring harness the same for all the cars that year and you just added on options or would i have to get a wiring harness with the relay?
Old Feb 1, 2006 | 10:07 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
The harness on the radios generally have the control wire,pink,for the power antenna.The relay harness would be either above the passenger side lower dash panel or kick panel.The early,'82-'84,cars have a single harness with the plug provisions for most options.I don't know if GM changed this after '85.Best way to do the conversion is to take the passenger side fender off.This makes it easier to mount everything.
Old Feb 1, 2006 | 10:12 PM
Car: 1989 Trans Am
Transmission: 7004r
antenna relay
Isn't there a wiring harness that plugs into the harness from the power antenna and then plugs into the relay? Did the relays come standard on all the cars so that you could add the power antenna or do you have to buy all that too?
Old Feb 2, 2006 | 01:38 AM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
my car came with one. I know the connection is under the plastic part on the dash under the "glove compartment". That wire should be there if you don't have the antenna. Also, I remember hearing a relay whenever I powered it on.
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
Bert87
Aug 23, 2015 03:50 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
novaderrik
Aug 10, 2015 12:44 PM
