AC HVAC Radio Trim Removal ???
Subscribe
Feb 16, 2006 | 08:02 PM
I am trying to remove the AC / HVAC Radio Trim from my 1992 Camaro Z28 but there appears to be a hidden screw (top LEFT corner) under the corner of the dashboard.
I removed all 3 screws that were clearly visable but I could not get the trim off.. Whatever is holding under that corner is stopping it from being removed.
http://www.camarosource.ca/temp/radio_panel.JPG
Reply 0
Feb 16, 2006 | 08:14 PM
Paul, there is a screw that needs to be removed at the top left. Remove that screw and the bezel will come right off.
Reply 0
Feb 16, 2006 | 08:17 PM
Quote:
Yes, I realize that. ;-)
However as you can see in the pic, the bottom corner of the instrument panel dashboard covers it..
Reply 0
Feb 16, 2006 | 09:52 PM
my 90 has a fake screw head in the upper left, only three hold it on. after taking the three out (upper right, and both lowers) it comes right off on mine?
sometimes they catch on the console peice (shifter plate/ ashtray) try removing the shifter plate first, or at least taking the screws out on it and pulling it slightly out of the way?
Reply 0
Feb 16, 2006 | 09:53 PM
I unbolted the HVAC control module but something is holding it in the car still. Looks like a cable? and a bunch of wiring.. How can I remove it?
Reply 0
Feb 16, 2006 | 10:45 PM
I posted this as a new topic : https://www.thirdgen.org/techbb2/sho...hreadid=347139 since the panel is removed, but a new question is asked.
Reply 0
Subscribe
