AC/HVAC Control Module removal??
Old Feb 16, 2006 | 10:45 PM
camarosource's Avatar
Car: Custom 1992 Camaro Z28 25th Anniver
Engine: 5.7L V8 350 L98 TPI
1992 Camaro - How do I remove the AC/HVAC Control from the car? I can't pull it out as something is holding it in.. I assume it's that stiff cable? If so, how do I remove it?
Old Feb 17, 2006 | 06:19 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
On earlier models (my 85), there's a tab on the cable itself that pushes into the control head from the bottom and IIRC is released from the top (back left side).
JamesC
Old Feb 17, 2006 | 08:54 AM
Stevo's Avatar
Car: Pair of 92 Z28s
helps if you take out the radio to get more clearance. Your gonna have to disconnect stuff from under and reach back. I beilieve once i removed the radio it came out a little further. There is metal rod that JamesC is talking about, but once you see how it disconnects its not hard at all. There are rivets holding vacumn plugs in the back also. I think like 4.
Old Feb 17, 2006 | 04:53 PM
You mean you have to drill out the rivots and re-rivot?
Old Feb 17, 2006 | 07:19 PM
90iroc5spd's Avatar
Car: 87 aniv vert, 90 Iroc, 87 LT
Engine: LB9, LB9, carbed 305
Transmission: MM5, MM5 conversion, MM5 conversion
Axle/Gears: 3.45, 3.73, 3.73
no you dont have to drill any rivets. the vacuum harness will pull off the back. the module can be a pain to get out though, pull the radio and reach in from there. have fun, it sucks. why are you taken it out?
you might be able to reach in from the front of the console also if you have skinny arms like me. take the deadener panel off the pass side and look in there with a light.
Old Feb 17, 2006 | 07:22 PM
change bulb
Old Feb 17, 2006 | 08:45 PM
JamesC's Avatar
You should be able to change the bulb without removing the control head.
JamesC
Frozer!!!
Jan 19, 2024 04:55 PM
justin57
Aug 20, 2015 07:05 PM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Aug 8, 2015 07:09 PM
