Bent Window Track
Old Feb 16, 2006 | 11:00 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Bent Window Track
Alright my passenger window track is dent so that there is a large gap between the window and the weatherstripping. This happened because the front stop quit stopping the window so that the window went to high. This caused the window to be shut inncorrectly bending the track.
I can't adjust the guides enough to fix the problem.
Should I remove the tracks from my window and try to bend them back?
Or take a complete setup out of properly adjusted door (ie by a whole door and switch internals)?
Old Feb 17, 2006 | 07:04 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Anything's possible, I guess, but I'd be surprised if the track itself is bent. Have you had the door panel off to verify?
JamesC
Old Feb 17, 2006 | 09:05 AM
Car: 91 Camaro RS
I've had it off numerous times. I guess track isn't quite the right term. Its actually bar that crosses to make an X and rides in the track. The part that actually holds the window, if that makes more sense.
Old Feb 17, 2006 | 09:34 AM
JamesC's Avatar
I suspect that would also be difficult to bend. Have you compared the guts of both doors?
JamesC
Old Feb 17, 2006 | 10:49 AM
Car: 91 Camaro RS
I've compared doors in the past but I've never had the panels off at the same time. Is it even possible to remove the arms that hold the glass?
Old Mar 13, 2006 | 11:57 PM
Car: 91 Camaro RS
Its been awhile, but I plan on taking both door panels off on Saturday evening and take a bunch of pictures. Now that winter is ending the rainy season begins.
1Aauto
Sponsored Vendors
Sep 23, 2015 12:56 PM
1Aauto
Sponsored Vendors
Sep 23, 2015 12:50 PM
Fronzizzle
Sep 8, 2015 12:10 PM
