Loc tite on paint
Old Mar 12, 2006 | 07:27 PM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Axle/Gears: Ford 9" 3.70
Loc tite on paint
Well it seems that someone decided to leave an open tube of loc tite sitting on my rear hatch The cover was on, so it soaked into the cover, and when I removed it, the cover stayed behind. Is there anyway to get the loc tite to dissolve without hurting the paint? I'm guessing the answer is no, and that I'm going to have to remove as much as I can, then wet sand the area down. This is on a base coat clear coat paint job. It was the clear general purpose stuff.
Old Mar 13, 2006 | 05:19 PM
Fast-Tony's Avatar
Car: 85' IROC & 87' IROC conv
Engine: Both have Vortec TPI 350
Transmission: T-50
Axle/Gears: 3:42 & 3:73
I would try contacting the Company that makes Loc-Tite Permatex? they might be able to help?
Old Mar 13, 2006 | 06:21 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
They make loc-tite remover....I've used it before but I am guessing it will also remove your paint too.
Old Mar 13, 2006 | 08:12 PM
90iroc5spd's Avatar
Car: 87 aniv vert, 90 Iroc, 87 LT
Engine: LB9, LB9, carbed 305
Transmission: MM5, MM5 conversion, MM5 conversion
Axle/Gears: 3.45, 3.73, 3.73
well I know that heating a bolt with loc tite makes em come right out, maybe try a hairdryer like you would on pinstriping removal?
Old Mar 13, 2006 | 08:14 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I somehow doubt the heat from a hairdryer will break down loc-tite.
Old Mar 13, 2006 | 09:23 PM
Fast-Tony's Avatar
Transmission: T-50
The heat may work Loc-Tite will soften at 300f, will the paint take that temp?
Old Mar 13, 2006 | 09:25 PM
TJC8974's Avatar
Car: 85 IROC/First Year Of The "Roc"
Engine: 305........for now
Transmission: 700R4/Corvette Shift Kit
loctite.........
I work at Home Depot and we sell the stuff. I'll ask a guy in the paint department and get back to u.
Old Mar 14, 2006 | 05:18 AM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Re: loctite.........
That would be great. So far, I've been able to get all the black marks from around the main bit by using compounds.
Hotrodboba400
Dec 10, 2019 07:07 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
e3pres
Sep 9, 2015 01:51 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
