headlights
Old Feb 19, 2006 | 06:04 PM
formulafastfoot's Avatar
Car: i have a 2003 ford zx2 and a 1989 f
Engine: 350 tuned port, 4 banger on the Z
Transmission: 700r4 poop loser
Axle/Gears: 3.23 standard ...one tire fire
headlights
im looking for a repair kit like hawks sells for a 1997 firebird ... know any places to get um ?
Old Feb 19, 2006 | 07:05 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
If you're referring to a repair kit with a CNC brass gear I have it. Just order the TDS 509210 Headlight Repair Kit.
Lon Salgren
Top-Down Solutions
Old Feb 19, 2006 | 07:14 PM
are they similar to the 82-92 with the 3 nylon gears,,,,
Old Feb 19, 2006 | 10:13 PM
lonsal's Avatar
No. The 1987-92 Firebird headlight repair kits are very different than this kit. I would say it is more similar to the 1982-86 Firebird headlight repair kits. Both kits consist of a CNC machined brass gear. The ForuthGen Firebird kit includes a new molded rubber insert. This helps absorb the shock of the headlight bucket hitting the physical stop. I caution you that there is an aftermarket version that doesn't have provision for this rubber insert inside the ID of the gear. I have a sample one that is totally chewed up by the worm-drive of the headlight motor.
Lon
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
