Door panel removal Help: any good way?
Old Feb 22, 2006 | 12:30 PM
triplerc's Avatar
Car: 1989 Trans am GTA
Engine: 5.7L 383ci
Axle/Gears: 4:10
OKay i have tan door panels and i want to dye them black and put new inserts in them , First i need to get them out of the car, i dont want to rip or break anything is there any tips or any good way of getting out with out me breaking anything, im not concernd with the plastic tabs, its the carb board backing.
Old Feb 22, 2006 | 12:35 PM
DJCobol's Avatar
Car: '89 Black IROC 'vert
Transmission: 700-R4
Axle/Gears: 2.73 posi
If you know enough to know of the plastic tabs, you dont need a full step-by-step then. My advice for those is to take an old fork and cut out the 2 middle tines. You should be able to slide the modified fork around the plastic push pins so you can pull them out without damaging the cardboard. Once all the plastic pins are pulled out, pull the bottom of the door panel out slightly and slide the whole assembly twoards the back of the car about an inch. You should be able to tilt the black plastic window trim piece back and lift the entire thing away from the door.
Old Feb 22, 2006 | 01:22 PM
sgt0704's Avatar
Car: 91 camaro rs
Engine: 305 tbi
Transmission: 5 spd
Axle/Gears: what ever stock is
make sure the wndow is down, and you have to push in on the black piece as you're pulling up on it. you may have to do one side first, and put something there to keep it from going back into the door, then do the other side. some times, it can be a pain in the *ss
Old Feb 23, 2006 | 01:37 AM
Black85sport's Avatar
Car: 91 Silverado
Engine: 350 TBI, EBL Tuned
You can buy a CHEAP tool for popping the little plastic "christmas trees" away from the door.
After you have removed your outside door hardware (pull handles and plastics), you can start by popping the door panel. .When you have popped them all off (christmas trees), lift and pull the door panel carefully and it will come off of the door.
Old Feb 23, 2006 | 02:05 AM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
Hmm, now Im wondering how difficult it is to dye the panels.
Ive got a BRIGHT red interior on the 91 z28 and Id like to convert it to black/grey like the post by another guy recently....took his interior which looks identical to mine and re did it all, and it looked SHARP.
*goes searching*
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
