Paint Gun thread
Old Feb 23, 2006 | 05:06 AM
HisDivineShadow's Avatar
Car: 1991 Trans Am GTA
Engine: 350 TPI (L98)
Transmission: TH-700r4
Paint Gun thread
IMHO there should be a stickied paint gun thread. For newbies like me who want to purchase a paint gun and are unsure of what to buy.
There are lots of brands(DeVILBISS, SATA, Bergen, Binks, Sharpe, SIP) and unlclear terms.
For example, what does nozzle size matter and what should I look for? Does it matter what I intend to paint with it?
I am looking for a gun to paint basecoat and clearcoat with.
Gravity feed or Suction feed? From what I've heard gravity feed is the way to go.
Right now it seems a DeVILBISS FLG-651G Finishline 3 is my best bet, it's 78 bucks without freight.
What are your experiences reccomendations? Maybe this thread could be stickied if it proves usefull?
Old Feb 24, 2006 | 02:28 AM
Hmm, well I've been searching for paint gun systems and I've picked up a few things on the way. Please correct me if I am wrong.
Nozzle sizes indicate what sort of paint you'd want to spray with them. For thicker and higher viscosity paints like primer and spray-on bodyfiller you want nozzle sizes of atround 1.8mm or so.
For basecoat/clearcoat painting you'll want a 1.3mm nozzle, atleast this applies for water-based paints I think, for thicker oilbased ones I think maybe 1.5mm? Or am I just plain wrong on this?
I've been thinking about this paint system, two guns, all metal and DeVILBISS brand, from The Eastwood Company
Old Feb 24, 2006 | 07:04 AM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
I use a 1.4 fluid tip for spraying color and clear. I've got three guns
Primer-Astro
Color=DeVilbisss GTI Millenium
Clear=Iwata LVPH 400
for a novice id get a GTI. they can be had for around $250 and will be quite user friendly.
Old Feb 24, 2006 | 04:37 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
my vote is for sata. im a huge fan of the NR2000.
Old Feb 25, 2006 | 10:31 AM
There seems to be a difference in using solvent or waterbased paints as well. Apparently in europe there will be a move away from solvent based paints in favor of water based ones due to new laws coming into effect in 2007.
Can a solvent and water based paint have the same color code, I mean that they can look the same?
Street Lethal
Apr 30, 2019 12:14 PM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
neekolzun
Aug 24, 2015 04:59 PM
ElPaleterro85
Aug 13, 2015 03:49 PM
