Removing rear seats
Old Feb 26, 2006 | 12:11 AM
MKnight's Avatar
Removing rear seats
Hey guys,
so far I have stripped the interior of my car, removed plastics and carpet from the back. What I'm trying to do is remove the rear seat but I can't seem to see any brackets or bolts to remove. Does anyone know where they are hiding?
Old Feb 26, 2006 | 12:21 AM
Justin Horne's Avatar
Car: 1982 Z28
Engine: 350 HO
Transmission: TH350 to go in next week
The bottom seats or the tops?
For the bottom:
In the middle of the front of the seat, under it, is the bolt.. That might not make sense, so I'll clarify.. Standing, looking at the rear seats: right next to the floor is what I mean by under the seat. This is where your feet go. In the middle of the seat, looking towards the rar of the car, feel right at the bottom of the seat, moving the foam around a bit.. There's a bolt there. Unscrew it, and the bottom piece comes off.
For the tops, and this is on a split rear seat car, it may be different..
After you get the bottoms out, look on the far left and far right, where they pivot. You'l see a bracket, a bolt, and a net. Take off the nut, and the seat will essentially come loose. It's also attacched to a rod kind of, to provide the center pivot point..
This is a bit confusing I think, but it should be relatively easy once you look around in the car for what I said.
Old Feb 26, 2006 | 01:58 AM
MKnight's Avatar
Thanks, I'll look at this tomorrow morning. These are the solid not split rear seats on my 82 TA.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
MORREALE5
Sep 13, 2015 09:16 PM
3rdgenparts
Aug 8, 2015 07:09 PM
z28addict8490
Aug 7, 2015 08:48 PM
