Ground Effects
Old Mar 4, 2006 | 08:00 PM
nick05's Avatar
Car: 1987 camaro
Engine: 358
Transmission: TH350
Ground Effects
I have an 87 Camaro and I want to put ground effects on it. I have the ground effects for the rocker panel, and I went to the junkyard today b/c there was a camaro there with the ground effects mounting brackets on it that I needed. I noticed that there was also a piece on the door. Do I need that piece? And how do I get that off? I dont know what year the rocker panel gorund effects were from, I know it's an R/S though. The car at the junkyard is an 86-87 Z-28.
Old Mar 4, 2006 | 08:38 PM
Blue_IROC_86's Avatar
Car: '82 Camaro Z28 (Former Pace car)
Engine: 85 5.7L Small Block
Transmission: WC T5
Axle/Gears: 96 disc LT1 3.23 Auburn 10 bolt.
hey man you need to cut those brackets off and weld them to your rocker panels.... they are very important....im sure you dont want to crack or snap your GFX when you get out of the car.....
Old Mar 4, 2006 | 08:48 PM
nick05's Avatar
Car: 1987 camaro
Engine: 358
Transmission: TH350
I was just going to bolt the brackets onto the rocker panel and bolt the ground effects to the like you are supposed to do. But I was asking If you needed the piece on the door, and after some searching of some pictures I think I need it. Now how do I get the piece off that is on the door?
Old Mar 4, 2006 | 08:54 PM
Transmission: WC T5
alright you have to take off the door panels, then the plastic behind it, if its anything like my car is missing completly. makes it easier.... along the bottom of the door on the inside there are bolts. i beleive they are either a 10mm or a 3/16 socket. theres also one on each end of the door. youll see what i mean. there easy to take off. ill try to find a pic for ya man....
Old Mar 4, 2006 | 08:55 PM
nick05's Avatar
Car: 1987 camaro
Engine: 358
Transmission: TH350
Ok, thanks, a pic. would help.
Old Mar 4, 2006 | 08:59 PM
Transmission: WC T5
alright its kinda hard to see. but on the lower corner of the door there is a black dot. thats a bolt with a cover on it for the GFX. there all at the same height on the door. just some are behind the panel.
and theres four of those i beleive
Old Mar 5, 2006 | 07:57 AM
nick05's Avatar
Car: 1987 camaro
Engine: 358
Transmission: TH350
Ok, I seen the bolt cover but didnt see anymore. I figured you would have to take the door panel off but wanted to make sure. Thanks alot!
$750 L98
Feb 1, 2025 02:25 PM
Falcon50
Aug 22, 2020 03:26 PM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
lewandom
Oct 1, 2015 08:15 AM
Damon
Sep 26, 2015 04:29 PM
