Engine Bay Paint.... questions...
Old Mar 9, 2006 | 10:36 AM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
Transmission: Built 700r4
Ok my first question is, What type of paint is more for engine bay duty?
Enamel or Laquer? I'm talking the cans of paint at your local autozone/advance. Which s made more for grease resistance, and which is not. What process should i go about when painting the engine bay,
Currently i degreased the entire engine bay with aeresol cans of degreeser, and a pressure washer. Got it really clean, got all resisdue off with dial kitchen soap(what i was told to use) and later a clean water pressure wash. I primered 2 coats. What is next? Do i clear coat afterwards? I didn't do much for straightening or sanding so i am pretty sure there is no need to clear coat as it will only make the imperfections look worse am i correct? But i also want logetivy from the paint.
Next question. My car will be painted the 4th gen Pewter. But i want contrast on the car. Should i paint the engine bay the same color? I was searching through the boards and did see different colors used in the bay. So what do people think about a black engine bay, Pewter exterior, and a GM Blue Engine(sorta like Pontiac Blue but used on GMC cars back in the day).
Old Mar 9, 2006 | 11:26 AM
LETZ RUN's Avatar
Car: 1986 ****** Camaro
Engine: 355
Transmission: th350
Axle/Gears: 3.42 10 bolt - temporary
you can see what i did here.. and the results..
https://www.thirdgen.org/techbb2/sho...hreadid=349071
i was told not to use primer unless it was a high heat primer. if you have excess heat it may cause the primer to bubble even if the top coat paint is high heat. who knows though. what i used for the paint was that 500degree low gloss black in cans at autozone
Old Mar 9, 2006 | 12:33 PM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
ok i was told otherwise. the engine paint doesn't have to be used on the car.
I'll have to make some more phone calls now... darn...
Old Mar 9, 2006 | 12:56 PM
LETZ RUN's Avatar
Engine: 355
Transmission: th350
its all in prefference.. i know i will have high engine compartment heat due to huge headers 2" stepped UNCOATED headers and 14.5:1 compression.
LETZ RUN's Avatar
Engine: 355
Transmission: th350
Old Mar 9, 2006 | 01:10 PM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
wel i used to have high under hood temps, in cold weather there would be steam coming from my hood.
all i have is 1-3/4 headers, and a maybe of 10:1 compression.
Old Mar 10, 2006 | 05:37 PM
nick05's Avatar
Car: 1987 camaro
Engine: 358
Transmission: TH350
What I did when I painted my engine bay not too long ago is grinded the rust spots down and primered the areas that I grinded. Then got some tractor paint which I think is a good choice because it is very durable and cheap, but I didnt like the color it was, (Satin Black) so then I just got some semi-flat black Rustoleum. If they had the color I wanted in tractor paint then I would have gotten the tractor paint instead.
Orr89RocZ
Apr 25, 2016 08:28 AM
Reddeath210
Oct 6, 2015 08:20 AM
Polo Z03
Sep 10, 2015 06:43 PM
AkDrifted
Aug 17, 2015 07:45 PM
jahblah
Aug 12, 2015 05:54 PM
