Engine Compartment Cleanup
Old Feb 27, 2006 | 09:15 AM
LETZ RUN's Avatar
Car: 1986 ****** Camaro
Transmission: th350
Axle/Gears: 3.42 10 bolt - temporary
Well I finally made a little progress on my junk. I cleaned up and painted the engine compartment. Came out okay in my opinion. Still neesd a couple more coats. I have about $30 invested in it for paint, laquer thinner, wire wheel.
Before....
Old Feb 27, 2006 | 09:16 AM
LETZ RUN's Avatar
Transmission: th350
after 1
LETZ RUN's Avatar
Transmission: th350
after 2
Old Feb 27, 2006 | 09:32 AM
jagevileye21's Avatar
Car: 1991 Z28 Vert
Engine: LT1 350
Transmission: T56 6 Speed
Axle/Gears: 3.42 LSD
Looks damn good!
Old Feb 27, 2006 | 09:44 AM
BABYBLUE_RS's Avatar
Car: 1992 camaro RS
Engine: 305 cu.in.
Transmission: automatic
Axle/Gears: stock
what brand of products are u using? also how many coats are u applying?plan on doing my rs but im leaning towards the por-15 .
thanks!
nick
Old Feb 27, 2006 | 09:48 AM
LETZ RUN's Avatar
Transmission: th350
just regualr dupli color low gloss black from autozone. that was 3 cans, gonna get another 3 cans and it should be good to go!. i hit it all with a wire wheel on a drill.. then blew it off, then 220'd id half assed... blew it off again, laquer thinner whipe down and then sprayed it.
Old Feb 27, 2006 | 09:50 AM
Car: 1992 camaro RS
Engine: 305 cu.in.
Axle/Gears: stock
looks nice man! plan on doing anything with your underbody and wheel wells next?
nick
Old Feb 27, 2006 | 09:53 AM
LETZ RUN's Avatar
Transmission: th350
i pressured washed everything with that foamy engine brite degreasser stuff.. whole under body of the car.. pulled tank out, got all up in there.
Old Feb 27, 2006 | 10:26 AM
Car: 1992 camaro RS
Engine: 305 cu.in.
Axle/Gears: stock
keep me/us posted, i plan on starting mine this spring/summer and im even doing the inside floor of the car for ultimate protection against rust,here in michigan we know all about that lol
nick
Old Feb 27, 2006 | 12:22 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
That looks 200 times better. Not to be mean you had one of the ugliest engine bays I have ever seen. Great improvement.
Old Feb 27, 2006 | 12:29 PM
LETZ RUN's Avatar
Transmission: th350
no man it was one of the ugliest cars yovue ever seen, lol. cant beat an $800 car that you drive onto and off of the trailer, and sell parts off the car for $950 and still have a body, 4" glass hood, draglights, panhard bar and lower control arms
The whole car was in horrible condition, this was just the first step. all of the interior is out, the doors are off, bumpers are off, every wire and hose and carpet and panel etc EVERYTHING is off of the car.
Old Feb 27, 2006 | 01:28 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Wow your at the point where you should put the frame on a rotisery and get the car blasted.
Old Feb 27, 2006 | 01:37 PM
LETZ RUN's Avatar
Transmission: th350
nah... its gonna be a race car (tehcnically, itll only race, but its not going to be certified). i want it to look decent, but low budget. My whole budget is to run 9's for 6k.. i think i got it covered as long as i dont get side tracked making stuff too nice lol
Old Feb 27, 2006 | 10:03 PM
smokeycamaro51's Avatar
Got a point......
If you really have it as striped as you said get it blasted. Remeber to go fast you gotta be light. So blast off all that sound deadining, undercoat. Everything. THen just give it a light and i mean light coat. Also on the underside try and spray it dry. Itll help the air under your car get out of from under it. NASCAR trick for superspeedways. That and itll help you when your welding on Sub frames and roll cages. Not to mention how good itll look. Try and look for a sand blasting pot if and do it yourself.
Old Mar 2, 2006 | 06:40 PM
JMJ2003's Avatar
Car: A beater.
Engine: Not enough HP.
Transmission: Automatic... I can't drive a stick!
Amazing job! Keep up the good work!
Old Mar 3, 2006 | 02:19 PM
$5003rdGEN's Avatar
Car: 1984 Camaro SC
That looks AWESOME! Are you going to take it down to Commerce?
Old Mar 3, 2006 | 02:45 PM
LETZ RUN's Avatar
Transmission: th350
car probably wont see the track. just race it on the street.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
Firebird sweden
Aug 16, 2015 05:02 PM
Randomtask2
Aug 13, 2015 01:57 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
