My turn lever broke
Old Feb 27, 2006 | 10:11 PM
82knightrider's Avatar
Transmission: TH200C....700R4
My turn lever broke
And now I cant turn off my windsield wipers.It split right in half.Is there a fuse I can pull in the mean time to shut off the wipers
thanks
Old Feb 27, 2006 | 10:30 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
You broke it
Old Feb 27, 2006 | 10:35 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
does GM still make the turn levers??
Old Feb 27, 2006 | 10:50 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I guess they do?
Old Feb 28, 2006 | 12:38 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
i bought one from the dealership last year???? I think i paid $23 for it after tax.
Old Feb 28, 2006 | 05:20 AM
techno101's Avatar
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
this may sound like a dumb question but do you need to pull the steering wheel to change the switch lever? If I turn to the left it pops back down, but if you turn to the right I have to push it up, springs worn out?
Old Feb 28, 2006 | 08:34 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
Yes, you will need to remove the steering wheel.
There is a screw that holds it on to the main turn spindle inside, usually this screw backs out. If you can, check it first.
Old Feb 28, 2006 | 10:51 AM
Thanks for the replies.23$ doesnt sound to bad and my g/f works at the chevrotlet dealership so im gonna look into that.
I have an 82 steering wheel,How do I take off the horn cap without breaking it lol
Old Feb 28, 2006 | 07:45 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
what broke exactly? the handle just pulls straight out
Old Feb 28, 2006 | 10:02 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I replaced mine from Advance Auto, in the HELP! section - I believe it was less than $23, with cruise control.
Old Mar 3, 2006 | 01:36 PM
heres a pic.I figured out how to usse my wipers.I just stick a needle nose in there and turn it
Old Mar 4, 2006 | 08:05 AM
techno101's Avatar
Car: 1989 Camaro RS
How did you manage that? Looks good, kinda got that "Mad Max" thing going on. I'd like to see it during the process of swapping it out. Mine is broken too.
Old Mar 4, 2006 | 08:34 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
The stalk itself just pulls straight out but you have to make sure the wipers are in the off position.And if you have cruise make sure you tie some fiching line or piano wire to the plug under the dash before you pull it out.It will give you something to pull the new lead down the column(spray it down with some silicone or even ArmorAll will work to help it move down the inside of the column).When you get it out you'll notice a tab/tang on the end of the stalk.Look in the cavity it goes in and you'll see how to line it up.It's a snap fit.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
FormulasOnly
Sep 10, 2015 09:07 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
