power seats in a 1989 Firebird Formula 350
Old Mar 14, 2006 | 07:22 PM
djashburnmn's Avatar
my moms boyfriend is installing power seats he just ordered into his firebird. he can get power to them but he wants to do it properly, so that the seats work and it doesnt mess anything else up. so where should he splice/tap into the power? i hope someone can help me out.
Old Mar 14, 2006 | 08:48 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I tapped into the cigarette lighter wire for positive power and used the chassis for the ground.
Old Mar 19, 2006 | 10:31 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
On some years the harness and connector may be there already.Have you checked under the carpet on the driver's side?If not,as Zepher stated,the ground wire is simple,could use one of the seat studs.You could run the pwr feed from the fuse panel along the factory wiring.
jaridjohn
Jul 8, 2024 03:49 PM
xkingcodex
Feb 12, 2020 07:43 PM
okfoz
Mar 9, 2017 02:35 PM
theshackle
Mar 5, 2017 06:37 PM
bellez77
Sep 5, 2015 08:39 PM
