Drip Rail?
Old Mar 19, 2006 | 06:13 PM
Ray102386's Avatar
Car: 83' Camaro
Engine: 355
Transmission: TH-350
Axle/Gears: Open...
Drip Rail?
There is a little rail looking thing that goes over the openings for the door. My passenger side has one but the one on the drivers side is missing or torn off like 3/4 of the way. I was curious as to what i can do or if i can fix this. IF i can get a replacement, where and how do i do it? All help and advice is greatly appreciated. Thanks.
Old Mar 19, 2006 | 06:19 PM
madathlon's Avatar
Car: 1988 Camaro, 1960 F-100
Engine: 2.8L V6, 223 inline 6
Transmission: TH-700R4, T98
Axle/Gears: 3.42/3.11 Posi Lock
Sounds like its time to shave off the drip rails...
Old Mar 19, 2006 | 06:44 PM
Ray102386's Avatar
Car: 83' Camaro
Engine: 355
Axle/Gears: Open...
keep going.....how do i go about doing this? Will it look alright if i do?
Old Mar 19, 2006 | 06:50 PM
madathlon's Avatar
Well shaving it off no big ting.. U need a cut off wheel and a grinder.. cut the rail off.. grind smooth some bondo and smooth.. primer and paint.. Will it look right.. thats all depands on if U like it shaved off or not..
Old Mar 20, 2006 | 11:48 AM
Ratchet's Avatar
Don't cut it off. It is just screwed on. You can remove it or replace it by simply removing the track that holds the weather stripping in place (hard part is finding the screws which are under the weather stripping) The drip rail is held on by more screws that are under the weather stipping rail.
Ric
Old Mar 20, 2006 | 01:17 PM
faulball67's Avatar
Car: 1986 IROC Z28
Engine: 350 carbed
Transmission: TH350
Axle/Gears: 3.43
You might as well replace the weather stripping on both sides while pulling out those ugly drip rails. I just took mine out today getting ready for paint. The big pain was pulling out the old weather stripping. It was glued in there and you would think that 20 year old glue would be brittle. Guess again.
Old Mar 20, 2006 | 03:12 PM
pondriver's Avatar
Car: 1992 Camaro ZO3
Engine: 350 HSR
Axle/Gears: 9 bolt/3.70's
They aren't available from gm anymore either.
Old Mar 20, 2006 | 03:45 PM
faulball67's Avatar
Car: 1986 IROC Z28
Engine: 350 carbed
Transmission: TH350
Axle/Gears: 3.43
what's not? The drip rail? If you want/need drip rails you just go to the junk yard.
Old Aug 10, 2010 | 07:18 PM
88camaroluvr's Avatar
Re: Drip Rail?
Does anyone have any pictures of the finished result of shaving the drip rails? And how does it perform in a car wash? I know they just keep rain from dripping inside when the door is open.
I don't take it out in the rain but I could always get caught in a drizzle.
What about the back side "drip rail" that holds the weatherstripping to the B pillar? Can you just zip the outer rail off with a dremel and still leave enough to attach the weatherstripping to?
I'm trying to get pictures and descriptions before I do this. Thanks.
Old Aug 11, 2010 | 07:26 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Drip Rail?
we've got the rubber ones now in stock for all of you looking to replace them. i posted a link in a couple other threads (don't want to spam too much)
gixxer92
May 18, 2017 11:20 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
Briandrex
Oct 5, 2015 06:20 AM
bplessy
Sep 30, 2015 12:14 PM
dusterbd
Sep 29, 2015 08:40 AM
