removing windows from doors without breaking
Old Mar 23, 2006 | 08:07 PM
faulball67's Avatar
Car: 1986 IROC Z28
Engine: 350 carbed
Transmission: TH350
Axle/Gears: 3.43
Since the search is down... I've got manual crank windows and need to remove them for paint and welding. I can't really tell where to start. I know how to get the triangle piece out from the front with the track but can't figure out where to go from there.
Old Mar 23, 2006 | 09:53 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
Remove the door panels and locate the rivets that attach the glass to the regulator - drill them out with the window partially "up" while a friend is holding the glass and it'll slide right out.
There are also 4-5 bolts under the door panel that attach the regulator/window assembly to the door that need to be removed. Get it out, clean it with laquer thinner, and lubricate the tracks with lubriplate before reassembly. You will need 1/4" rivets and rivet gun (expensive) to reattach the glass to the regulators and install them as an assembly if possible.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
3rdgenparts
Aug 8, 2015 07:09 PM
