Drivers side weather stripping????
Old Apr 3, 2006 | 03:59 AM
sheltonw3's Avatar
Car: 91' TRANS AM Modified
Engine: Classified
Transmission: Auto with Overdrive
I am helping out a friend who owns a 92' hardtop firebird and the weather strip on the drivers side door is worn to where it leaks water when it rains and he needs to replace it,but it looks like the strip is glued ,is there a safe way to remove or should we just rip it out and hope for the best and just replace the strip?.....thanks in advance!
Old Apr 3, 2006 | 08:27 PM
Cornholio7979's Avatar
Car: 89 Formula, 89 IROC
Engine: GMPP 350 HO, L98
Transmission: 4l60x2
Axle/Gears: not enough, good enough
I just replaced that same weatherstripping on my 89 hardtop bird. It was glued in, and because it was so old and beat up, it came off in pieces. I had to go back with a flat head screw driver to clean off the remaining pieces. I go the NOS weatherstripping from Hawks and it went in perfectly. Didn't even need glue. If you can get the stripping in the slots it's designed for, you won't need any glue.
Old Apr 3, 2006 | 11:14 PM
sheltonw3's Avatar
Engine: Classified
thanks ,thats just what I needed!...I already got the stripping ,just wasn't sure about the best way to remove the old one?
1992 Trans Am
May 10, 2023 07:19 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
I'llrocya
Nov 11, 2015 05:45 PM
g.l.mos
Aug 22, 2015 12:02 AM
timonator
Aug 11, 2015 09:56 PM
