Hi/Low Beam Linkage? Need Help!!
Car: 91Camaro RS
Engine: 305TBI
Transmission: 5-Speed
Axle/Gears: 3.08
I was ripping apart my steering column last night to tighten down those 4 torx bolts b/c its a little loose. Lets just say it's not going too well. Thats another story though....
My question is this: What is that plastic piece called that attaches to the hi/low rod and extends to the turn signal lever? I put the column together quick to see if I could fix that, and they were stuck on brights, then redid it and now its stuck on low beams. The switch does not activate when i pull the lever for hi/low.
What piece do i need? Or what am I doing wrong? Is there anyway I can rig that plastic piece to stay put? When I pull the collar off, that plastic piece just falls out, and when I activate the lever for hi/low it clicks (sounds like that piece slips off the rod) and i take it apart again.
Sorry for the confusing post, its kinda hard to describe something without knowing the name of something.
Any help is GREATLY appreciated.
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: A/T
Car: 91Camaro RS
Engine: 305TBI
Axle/Gears: 3.08
This is a pic I found on some dude's article about doing the tilt repair...
Is there a special name for it so I can just get a new one? It falls right off, unlike in the pic.
Car: 91Camaro RS
Engine: 305TBI
Axle/Gears: 3.08
ok, I found that part, so ignore above post
Now I was wondering when I'm putting my steering column back together, should I get anything else? Or can I re-use all the original pieces. I saw on rockauto they have a couple seal kits for the steering column????
I'm going to try and get a new turn signal lever as well, since the one in there is really loose. And since im replacing that dimmer switch activator, I may as well fix them both.
LT1Formula
Oct 8, 2015 08:34 PM
IROCNParts
Sep 24, 2015 10:50 AM
