removing stripes
Old Apr 13, 2006 | 05:48 PM
bandit45's Avatar
removing stripes
my vinyl stripes are cracking like crazy, how do I remove them? I've heard a heat gun, how difficult is it and what is the procedure? I've ran a search and havn't found 2 much.
Old Apr 13, 2006 | 06:20 PM
CYARS92's Avatar
Car: 92 Camaro RS, 72 Camaro SS
Engine: 305TBI, til it pukes
Not that complicated, just time consuming. Heat it up and start peeling. Do small area's though. Also try to find a PLASTIC scraper to help you peel it. Once the decal is off try to find some 3M adhesive remover - apply it (spray bottle) and depending how much adhesive is left, let it sit for a minute or two and scrape it again. Then you may want to apply some to a rag and wipe the whole area. Don't scrape to hard though so you don't scratch the paint! When done buff it, wax it & drive it. Good Luck!
Old Apr 13, 2006 | 06:32 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
you can also use one of those rubber wheels made by 3M you put it on a drill and it removes the stripe and the glue behind it all in one process. hit up your nearest automotive detailing store for one of those
Old Apr 13, 2006 | 09:43 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Just remember that heat guns can remove paint, so keep it moving if you use it.
Old Apr 14, 2006 | 11:28 PM
bandit45's Avatar
Thanks for the help fellas I worked on them today using a hair dryer. It worked fairly well, but it's taking me forever and the hair dryer burns like hell. Where's a good place I can get some new stripes that won't crack so soon?
Old Apr 15, 2006 | 12:22 AM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
Paint them on. I bought a pin striping brush, and if I decide to put mine back on after I remove them, Ill just paint them on. If you need a straight line, use the painters tape.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
Jsapp38
Nov 13, 2015 07:38 PM
Stroopwafel
Sep 11, 2015 06:38 AM
Ironhead38
Sep 7, 2015 02:26 PM
