removing Interior door trim with window rubber
Transmission: TH200C....700R4
Originally Posted by transamworld
I was afraid of that, I thought I may get lucky and it would only be clips or pins. My inside window rubbers are coming away, is this a common problem ?
Car: 1985 Trans Am
Axle/Gears: 3.70
Originally Posted by 82knightrider
yes its a problem.Too remove the window sill you need to first have the window down.Then take off the door panel carefully.Then once all that is out of the way push the window sill in and up and it should come out.When I removed mine I dont remember seeing any bolts and nuts
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
