is there a kit for this???????
Old Apr 18, 2006 | 03:44 PM
ChevyRS-305's Avatar
is there a kit in which i can have shaved doors that open by remote AND have lambo doors that also open by remote??????
is there any way i can put it all on one frequency?
Old Apr 18, 2006 | 04:03 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
You should be able to use a regular door popper to pop open the scissor doors.
Old Apr 18, 2006 | 05:04 PM
WckdDudeMan's Avatar
well you wont find it all in one kit but it can be done, one company i know makes door popper kits for shaved doors, autoloc. not sure who sells lambo kits cept the go for about a grand for the hinges.
Old Apr 18, 2006 | 07:41 PM
r0nin89's Avatar
Car: 1987 Chevy Stepside
Engine: 350 TBI w/ a Cam
Transmission: 3 Speed Stick w/ granny low
Seen em for like 200bux...
Old Apr 18, 2006 | 09:50 PM
a cheap one or a real one? real lambo kits all run about 900 you can get a cheap one or make your own for less(well making your own is tough i know a few who did it on there cavies and took a few months of testing and fabbing to complete without too many flaws).
Lambo Door Kits VDC Door Kits Decah Vertical Door Convrsion Kits
Vertical Doors |82-92 Chevrolet Camaro at Andy's Auto Sport
Chevrolet Camaro Lamborghini Door Kits - Auto Lambo Door Kits @ Car Parts Wholesale
heres a KIT(not just the hinge)
Vertical Doors, Inc -
Old Apr 18, 2006 | 09:57 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
That is sincerely disgusting. Why would you even consider putting that overpriced ******* contraption on a camaro?
Old Apr 18, 2006 | 11:24 PM
the only reason to do it is:
gets heads to turn regularly(except at shows)
shows are what people usually get it for but its played out at shows... a real stopper at shows is the shaved suicide doors... add that with a center cut sideopen hood and you got a pimp *** ride that almost no one will have a copy of.... oh yea and this also goes awesome with the iroc hoods which look like they were made to be cut down the center...
and if you want to do even more work to wow the crows. switch to a flat back(the fiberglass notchback thing hawks sells). but dont stop there design it to open backwards using modified buick lesabre hinges, have it slide back and down to cover the tail lights, or have it side open like the hood, now that would be a show stopper... maybe add in a custom built sub box in the trunk with 4 12s.... and finish the sound system inside and you will have yourself a 100% guarunteed show car winner.
1Aauto
Sponsored Vendors
Feb 8, 2017 03:09 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:25 AM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
