leaky fuel filler
Old Apr 20, 2006 | 01:30 PM
redliterunner's Avatar
Car: 89 IROC convert.
Engine: tpi 305
Axle/Gears: 3.42 10 bolt
leaky fuel filler
When I fill my camaro up with gas, it leakes like crazy from somewhere up high in the quarter panel, like it's something right behind the gas cap. Is there a seal or something somewhere in there between the filler neck and tank that might be bad on the car?
After it's driven a few miles, the leaking stops, but the car almost always smells like gas.
Thanks in advance.
Old Apr 20, 2006 | 01:39 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
It could be alot of things, Theres feed lines, return lines all in that area if it doesnt affect the cars performance it may just be a return line, those are low pressure, as to the feed line has 40 or so psi in it, I suppose is get a friend or someone to look under it ( with some safety glasses on lol it is gas) And see where it is coming from theres a rubber line that crimps into a steel 3/8 you may be lucky and it might be that one, Let us know, hope this helps
Now thats the lines that could be spraying, of course the main Fill tube ( sorry dont have tech terms) could be your culprit as well you gotta have someone under there
Old Apr 20, 2006 | 02:01 PM
Engine: tpi 305
I parked the car on an incline yesterday, and looked up under it. It looked like it was leaking where the filler neck goes into the tank. Can I access that area through the fuel filler door, or will I have to drop the tank?
Old Apr 20, 2006 | 04:19 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
migt have to drop the tank, since its on the top, hopefully someone who knows more then i do will chime in
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
Catcher55
Aug 15, 2015 07:08 PM
92camaroJoe
Aug 13, 2015 06:07 AM
